Garfly
Everything posted by Garfly
  1. Yeah, the SE2 works on Pressure Altitude so, in effect, it's always sending Flight Level, not AMSL. ACAS systems all use PA since they're only really interested in own-ship's vertical relation to nearby targets; high or low, trending up or down.
  2. Max Holste MH.1521 Broussard - Wikipedia EN.WIKIPEDIA.ORG
      • 3
      • Like
  3. And maybe find a white hankie to shield it from the sun's heat. Your buyer's remorse is sure to lessen the first time it saves your bacon. (Or even just saves some needless worry once in a while ;- )
  4. Sure, if an airline pilot hasn't done any GA flying in 30 years then they'd probably want and need some transition training before going over to RA. But that's a process they've been used to their whole career. These days, though, a pilot leaving GA for RA might be going, say, from a draggy old Maule to a slippery Pipistrel. (Or a thirty-thousand hour ag pilot going over to ... well, anything). Not exactly what the regs had in mind. So, yeah, while transition training is always advisable, it no longer makes sense to mandate a fixed number of hours for candidates who don't need it. Competency based testing is now fairly well accepted in aviation. P.S: An interesting FAA take on transition training: https://www.youtube.com/watch?v=TpxJIr4dsF8 "The lack of transition training has been cited as a causal factor in many GA accidents. Accidents frequently result from pilots being unprepared for challenges presented by the new, or different, aircraft they are flying. Even when pilots are legally certificated to operate aircraft within a specific category and class, significant differences can exist among different types of aircraft within that category and class — thus necessitating the need for effective transition training."
  5. What?! RAIM is a concept used in IFR ops. Anyway, even if the whole GPS system did drop out (ever happened here?) you'd still have your (approved) iPad charts to read - easier to handle (and enlarge for detail) than finding and unfolding paper ones in a hurry. You'd use them with your compass and watch and paper flight plan you have as back-up. If your iPad dies then you fall back on your phone and/or spare GPS and the paper charts you do have in your flight bag. Well, at least you have a fix on where you were a minute ago - before the sky fell in - as it's so wont to do. I don't suppose this CASA guy would be asking if you'd considered taking up the feds offer of a nice new half-subsidised SkyEcho2. Of course not! They don't believe in all that 'distracting' tech stuff. Never have. What's wrong with the Old Eyeball v1.0!? Worked for him (if not, sadly, for everyone).
  6. And, in some cases, much less, I guess.
  7. Yeah, there's a fair bit in OzRwys that wasn't in my old Garmin12 from the early 90's. It had one of those much maligned GoTo buttons, though. The GA establishment was not impressed; certain that the sky would fall in if ordinary aviators ever got access to such thingies. Stories abounded of hapless GoTo navigators blundering into airspace and mountains, blindly following their diabolical handheld GPS thingies. Few of those stories were true but the suspicion of GA GPS (despite the obvious benefits) hung around for a good long while. Now it's ADS-B. Go figure.
  8. I'm a bit surprised that you would - or even could - be required to undergo such a demanding, costly and wrongheaded BFR. In my opinion, their insistence on your having to use way-out-of-date, and demonstrably less reliable, less safe nav methods seems weird. Some kind of confirmation rite of yore. That's no way to test for competence and safe airmanship in today's complex aviation environment. (Even if there's still a case to be made for ab initio training in the old ways.) I'd be interested to know which arm of CASA did the deciding on this - and on what basis. Is this normal? In any case, AFAIK, you'd not be required to do any nav test as part of your conversion to RAAus. So I guess you'd be trading in your Mooney, then, for something more on the ultra end of things. ;- )
  9. Philster, As soon as I turn my unit on, the middle green "ADS-B" light starts flashing - even before it gets networked to the iPad/OzRwys. So that suggests to me a problem with your SE2, itself. (There are tech savvy folks on-site who'll know more.) In any case, OzRwys does have an indicator on its main map page (upper right corner) confirming the traffic IN/OUT status (both of its own [cell-tower based] system and any integrated ADSB device.) So if you're not seeing the green radio-wave symbol (see pic) together with your ID 1234 and '1200') then you know your SE2 is not transmitting. More info here: OzRunways Knowledge Base - SkyEcho 2 ADS-B IN/OUT SUPPORT.OZRUNWAYS.COM
  10. Yes, Skippy the Ping gives you the same info as the SE2 and in the same format (at least within reasonable range of your own ship). But anyway, not all Mode S transponders transmit ADS-B so if yours does not send the "extended squitter" bit, as I understand it, you'd be good to go with using an SE2 to its fullest. That way you would have both the poor man's ADS-B IN/OUT solution as well as the rich man's proper transponder. That means you could continue to operate in Class-E, you would have the benefit of surveillance by Centre, you will be more likely to be detectable by TCAS and you will probably, when the time comes, be entitled to request clearance to transit controlled airspace, even in an RAAus craft on an RAAus ticket. (If I have anything wrong, I trust I will be corrected.)
  11. Further to the above, F10, maybe I missed the drift of your question. By "just" Sky Echo, did you mean without it even being paired to an iPad (or similar)? In that case, the answer to your question would be yes, as long as the other aircraft had IN as well as OUT (and was set to show "conspicuity" type targets). But pretty much everyone who uses a SkyEcho2 links it to an EFB (which they likely have anyway) so that they can "lookout" for all the ADSB traffic within Cooee. Nowadays, of course, all IFR aircraft show on screen plus an ever growing percentage of the rest. The more the merrier, and safer.
  12. Negative, re that SkyEcho question, F10. Heaps of discussion/information on the topic here on the forum. But, yeah, I reckon your old RAF mate was damn right to be paranoid. Heck, anyone who goes out of their way to get a SkyEcho is paranoid too. (Especially the ones who've learned not to fully trust their lying, limited eyes. )
  13. By a disease analogy ADSB is, to me, not about treating symptoms nor causes; it's a prophylactic. (And a pretty cheap and effective one, too.)
  14. F10, would you care to expand on that "knee-jerk" comment (especially in light of the frequency issues we're hearing about)?
  15. I believe that "Affirmative" is never correct (due to its sound being too close to "Negative"). And whereas "Affirm" is only ever used as an answer, "Confirm" is only ever part of a question.
  16. From ABC News yesterday: "An inquiry into a helicopter crash off the north Queensland coast heard the ADF ignored safety concerns from Major Ian Wilson and two other test pilots about high-tech helmets before four aviators died in July 2023. // Major Wilson said in testing of the upgraded technology to the helmet-mounted visor used by pilots, he had found serious inconsistencies between the pitch, roll, bank ... information that the TopOwl 5.10 provided ..." https://www.abc.net.au/news/2024-10-18/taipan-crash-inquiry-test-pilot-apologises-to-families/104489668?utm_source=abc_news_web&utm_medium=content_shared&utm_campaign=abc_news_web&utm_content=mail From 9 News yesterday: The background from 60 Minutes 2 months back:
  17. Backcountry Larry has uploaded some videos explaining his AoA indicator and how he uses it.
  18. Nev, could it be that both pilots neglected to set QNH on approach?
  19. Yeah, well Area QNH is often an approximation of local QNH at a given time and place. The main aim being that all aircraft are on the same pressure datum to keep clear of each other vertically whilst enroute. But, of course, the Area QNH can't be too far out because we need to avoid terrain as much as each other (below the transition level). So the Area QNH changes regularly to track the changing atmospheric pressure. And yes, you do get the accurate Local QNH by dialling up your known field elevation but that's just for that exact time and that local area. I guess it's good to keep in mind that arriving or overflying aircraft are likely to be on Area QNH (at uncontrolled fields).
  20. Brendan, this is the extent of your local QNH Area as shown in OzRunways (if that's what you were asking about): CLICK FOR FULL REZ:
  21. Another thing I took away was just how much time there was - a good 5 mins - between Centre's first traffic advisory and the collision. Time enough for all the 'taps and glances' needed to track on a moving map the icon of a pre-alerted threat. (But then, there must have been some pretty full-on instruction going on at the time, in both cockpits.)
  22. Mike, when you said, a few posts up, that: "I’m not naming names or locations etc." I think something went awry with the forum's Quote feature such that it looks like Thruster is replying to my question to you. In any case, on that issue, I don't see a problem, per se, with the opinion (that is, that a cockpit traffic display would NOT likely have prevented Mangalore). For all I know, the argument might have made a point - or turned something up - we could've learned from. When all's said and done, we're all of the same Safety-First faith (just as, I guess, we'd all claim to be doggedly anti-dogma ;- )
