Bennyboy320
Everything posted by Bennyboy320
  1. Redcliffe aero club are doing a mass fly in there soon for lunch, give them a call & tag along.
  2. Why does it take 6 weeks to get an Aus Check with your application when security id can get theirs done in a matter of days? Then another month to get a card printed by government outfit, sounds like a complete cluster #### to me.
  3. Security ID will send you your new ASIC, in the post pack they include a self addressed envelope for you to return the old card, as I've said it doesn't get any easier than that, I still can't believe how difficult some agencies make this relatively simple process.
  4. As mentioned on previous threads, avoid going through RAAus or CASA, use a third party, I've used securityid.com.au for my last three renewals plus the initial of course, all done online & you get your ASIC within 10 days from applying. Obviously a bit late for you now but think about it for your next renewal.
  5. Jeez, how do you stop on such a slippery surface? It's difficult enough to walk on let alone operate an a/c, well done.
  6. You definatly get spoilt with 2 engine jets, even in the sim at 40 degrees celsius & MTOW after a V1 cut obstacle clearance never a problem, if is is just follow the company designed engine out procedure. My 5 hours in the Duchess to do my CIR was an eye opener with regards to the limited performance of these a/c, I would hate to be in one at MTOW.
  7. Just quoting the FAA Reg that do not require any single engine climb performance for light twins <6000lbs OR have a stall speed of 61kts or less. Again with limited GA experience I wouldn't have a clue what a/c types that includes?
  8. Speaking with a total of 5 hours on GA twins there is no requirement to achieve a positive climb gradient for the second segment, i.e. The remaining engine will only take you to the crash site depending on the weight at take off.
  9. Sorry to hear that Peter, the easiest way is using securityid.com.au Fill out your personal details on their web site & get you documents certified at the post office for $4 then email it all to them. It's that easy.
  10. Yes sir you are 100% correct, however from their web site they (CASA) will fine you for not having a valid ASIC when required, just looked at the fine, it's $550 each time, still have never seen or been approached by an ARO even after requesting parking information from them as just mentioned by gareth in the post above. Yes I have a valid ASIC which was just renewed, like all my previous renewals (three) it was seamless & took about 10 days to receive my new card from the renewal request, why change things if it ain't broken.
  11. This is getting absolutely ridiculous, I mean how many light a/c or GA/RAA type pilots have committed a crime let alone a terrorist act on an airfield that has RPT ops in the last 50 years for example, I think its zero, nil, none, nadah, zilch. What moron would make the process more complicated than as mentioned in a earlier post getting a passport, isn't the terrorist choice weapon trucks these days.
  12. Or an L2/L4 as recognised by RAAus.
  13. Minor point it's a Vixxen A32 not a Foxbat A22LS.
  14. Lets all hope commonsense prevails & the changes happen soon, personally I think it will happen in conjunction with canceling the requirements for an ASIC.
  15. Definitely have it in a handy location, if I'm solo it's around my neck, if I have a pax its around their neck & I brief then what to do if required. The GME MT410 was about $320, very easy to activate too.
  16. He was the last of the Mercury Seven, "Gods speed John Glenn."
  17. On the membership section it only allows me to input hours since when I joined RAAus i.e. 2012, everything prior not counted.
  18. Here’s the simple way of understanding the system, I’ll use two examples, the first is my Foxbat. It has an individual 24 bit/ 6 digit hex ID & the flight ID has been locked in as R1234 as an example as this combination will never change,(as per the Air Services requirements,) unless I decide to get a new mode S transponder or change my rego, on domestic flight plans my call sign is e.g. 1234, however my ATC call sign is Foxbat1234 ref AIP GEN 3.4-22 The next example I will use is an airline flight, again the 24 bit/hex code is an a/c’s individual ID, I am flying from Hong Kong-Taipie so when I set up the flight management system I must ensure that the ICAO airline code & flight number up to 7 digits long matches the call sign on the flight plan e.g. HDA486, however the ATC call sign is Dragon486, clear as mud? Now if that original a/c goes tech & a swap is required, no problem the FMS is loaded on the new a/c, the a/c again has its individual hex code & HDA486 would be inserted as above. When ATC look at their scopes they will see that R1234 is a recreational a/c for quick ID & QF1234 is a Qantas jet, have a look at Flight radar 24.
  19. Sounds like an epic trip, enjoy
  20. Tail draggers are much more difficult to operate, don't worry it'll come with more exposure to them, hang in there.
  21. I HATE BLOODY SPELL CHECK:im stupid:
  22. When ICAO brought in the language skills requirement there was nothing on anyones licence reference language skills, most companies have people in house now to conduct the tests, in my case Hong Kong locals (who's second language is english ) who have been blessed by the HKCAD i.e. CASA equivalent to conduct these tests, when they were first done some years ago all our pilots were tested by an Oxford uni language boffin, like Robbo mentioned it was no walk in the park.
  23. Did my PPL in Maitland in 1980 & most of my RAAF flying out of Willytown, I too was absolutely blown away at the size & number of these open cut mines when seen from the air recently from an airliner, I suppose things change in 30 odd years, maybe the will become prime lakeside real estate one day.
  24. My company has a few Aussies that speak no other languages & were assessed as a level 5, the test is taken very seriously up this neck of the woods, it was more of a compression test than a language skills test in my opinion, level 4 required to fly commercially, jeez some of the people I've heard flying airliners I'd give them a level 1.
  25. The aircraft was 100% serviceable & doing what it was supposed to, the pilot can always go around at ANY altitude & ANY FMGC mode by manually pushing the thrust lever to the fire wall i.e. selecting TOGA, the same thing almost happened to Jetstar except they didn't crash at MEL 21JUL07 JQ156, both incidents caused by poor systems knowledge.
