RossK
Everything posted by RossK
  1. The Aeroprakts are good examples for you, both will have usable loads over 600lb, which means you can get you, a 200lb instructor and a reasonable amount of fuel on board. An idea would be to contact the Aeroproakt USA dealer and ask them if there are any schools near you using them.
  2. Add me to the manual flap fan base. Did all my training in a J160 with electric flaps, and now fly a plane with manual. Much easier to use than the electric.
  3. Hi Jay, there are plenty of LSA that have decent useful loads, the Cessna 162 would be one of the lowest, so not a good choice for you. Our own Evektor Sportstar has a useful load of 254kg (559lb for you) and there are aircraft out there that have more. Don't give up on your dream, just do some research on aircraft and find a school with those aircraft. Of course, losing a little bit of weight would be good thing, both for yourself and your flying 😃 - I've lost 8kg this year just so I can carry more fuel/baggage.
  4. Yes, but it's reducing the risks; If you're vaxed less likely to pass it on, less likely to get sick, less likley to require hospitalistion, less likley to require ventilation and less likely to die. Israel still have 80% of deaths being fully vaxed, but the infected mortality rate has dropped from 4% to 1.5% Oh, and by the way, I'm at the stage where I'm seriously considering ignoring the rules and going for a fly. I can fill up my jerries at the local servo when I fill my car, drive to the airfield, fly, top up the tanks, and come home. I will have had zero interaction with anyone else or any other equipement than I would in my normal weekly routine. And to top it off, recreational fishing is allowed, so why not aviation!
  5. Because if you have C19 and are unvaxed, you are far more likley to pass it on than someone who is vaxed.
  6. It's normal, people still blame John Anderson for the state of Aviation in Australia.
  7. I've just read the last 2 pages and I'm no longer worried about the supply of toilet paper. It's aluminium foil I'm worried about now. Far too many people are making tin foil hats with all the conspiracy theories in their heads.
  8. Also discussed here
  9. Just remember, whilst Scomo has his faults, if he didnt' stand when Turnbull stepped down, we would have had Peter Dutton as PM - he had the numbers to beat Julie Bishop. Think about that, Dutton as PM 😬 😲.
  10. Yamaha EPeX aero engines 150hp - 300hp @ 10000rpm depending no NA or Turbo
  11. As a centre right kinda guy, what concerns me is the shift in both parties to the extremities. We don't seem to have any decent politicians who are centre left or centre right. The consequence of this is we see the vocal parts of our society mimicking our politicians, with no middle ground represented. You are either right or wrong depending on which side you are, none of your opinions can be considered as valid if you don't agree 100%.
  12. That's confusing actually, as the ATSB report says the prototype had 340 hours flight time and it was the production version that crashed after 17 minutes. Doesn't say whether it was single or two seats though. "This aircraft was intended to be the production version of the "Stratos" aircraft. The prototype version had successfully flown some 340 hours. The production model incorporated significant changes made by the designer/pilot."
  13. get yourself an early MX5, old british sports car dynamics, with japanese reliability, and one of the sweetest manual gearboxes you'll ever shift.
  14. Fuel pump off helps with radio transmission apparently. Technically, turning base is the only call you're required to make, so if he was doing circuits that's all he would be making. But yes, he should have heard your joining call and either spotted you and made room, or called you and let you know where he was, so you could make room. I am aware of some pilots that think that as they are in the circuit, they have right of way, so the only call they need to make is turning base and the onus is on the joining pilots to see and avoid - similar to some guys I sail with who won't call starboard as the the onus is on the port tacker to see and avoid them. Neither is great when the give way person doesn't see them and a collision occurs. Both water and air are very unforgiving environments to have that attitude.
  15. I've had a couple of incidents where another plane has reported position exactly where I am 😲. It really gets the adrenalin going. First was in the circuit when I was mid turn from crosswind to downwind, the local Jump plane called joining downwind 😬. A quick scan couldn't find him so I called him and reported my position. He replied that he was 500m off my left wing and slightly higher - got him, and he had me visual. He overtook me and turned base about 500m in front, those guys are always in a hurry. Second was on the VFR route from Kilmore to Sugarloaf. As I was abeam Yan Yean I reported that I was 2 miles abeam Yan Yean at 2500 tracking to sugarloaf. Within 10 seconds there was a call from a GA plane saying he was 2 miles abeam Yan Yean at 2500 tracking to sugarloaf. a quick scan found him about 1 mile further out and about 500ft higher. Not sure if he was trying to be annoying or not, as he was clearly not on the VFR route and in the 4500 class C step, or he just didn't really know where he was.
  16. Agree, if the small minority of selfish people could just do the right thing for a couple of weeks, we'd be done with this by now.
  17. Good to see someone got to commit aviation on my Birthday!
  18. Already paid Draco
  19. Having watched the Wasabi Test Vlogs on this Airframe and then some of the Raptor ones, this is un-surprising. Glad he is OK, looks to have done a better job than Dan Gryder !
  20. Wax and grease remover from any paint shop. That's what i used.
  21. I do actually agree with everything you've said. I posted that as an example of what we went through last year and that if the government has the resolve to do it, significant outbreaks can be overcome. I've been through a real lockdown, had my business suffer financially, retrenched staff, not seen my kids and grandkids for months. had my vaccinations. It all hurt - but I'm glad we've done it as the alternative is worse, in my opinion.
  22. extract from an ABC article from last year on Victorias lockdown; As the city's first-ever widespread curfew came into effect at the weekend, 5 million people suddenly found themselves living in a dystopian novel. Police now patrol the streets with expanded powers, smashing the car windows of those who refuse to give their details. Pre-recorded government messages ring out over loudspeakers in empty train stations warning of the virus. Door-to-door checks are being carried out by police and Defence Force troops. And those caught on the streets between 8:00pm and 5:00am now need to carry government papers to prove they are allowed out.
  23. Agree that contract tracing is pointless, no system can keep up with the potential 1000+ additional close contacts per day. But, this is beatable. Melbourne did it last year from a position of 600+ cases a day. I don't think people outside of Melbourne realise how strict the lockdown was, what NSW has done to date isn't even close. The Virus doesn't spread, people spread the virus. If you stop people from moving, you stop the spread. Simple. Waiting for herd immunity isn't the answer, it will take too long. Gladys needs to stop asking people to do the right thing, and demand that they do, and follow up with enforcement. If NSW had done a Melbourne style lockdown at the end of June, they would be out the other side by now. Tougher restrictions now will get this done by early September, but I don't think Gladys has the nerve to do it.
  24. Boats pay Registration. Better Boating Victoria has lobbied the state government successfully for free parking at ramps and several ramp upgrades in regional VIC, using the argument that the registraion fees should go to boating facilities.
  25. I bet that really affected them 🙄
