coinz Posted April 4, 2014 Share Posted April 4, 2014 Hi guys,engine is a KFM 112M ,hasn't been run for a while,only 300 hours.When turning the motor on the prop there's a clicking noise,somewhat like a impulse connection but more a clicking evenly spaced and not as loud as an impulse.It's there turning it either way,and there for the whole revolution.Evenly spaced,like every 5 degrees.Motor turns smoothly,no grating .It seems to be coming from the front. Any ideas before a complete teardown ? regards colin Link to comment Share on other sites More sharing options...
Ultralights Posted April 4, 2014 Share Posted April 4, 2014 could it be valve train with lack of oil? Link to comment Share on other sites More sharing options...
coinz Posted April 4, 2014 Author Share Posted April 4, 2014 I guess that's a possibility,but the sound appears more to the front of the engine. Link to comment Share on other sites More sharing options...
coinz Posted April 4, 2014 Author Share Posted April 4, 2014 Well i've done some searching and it's possibly a dry Gerator oil pump.Just needs priming possibly.Will have a go at it this morning,fingers crossed Link to comment Share on other sites More sharing options...
facthunter Posted April 5, 2014 Share Posted April 5, 2014 How long is a WHILE and was it inhibited? You can't just let motors sit and then fire them up and fly years later. You should pressurise the oil system before running and check cylinders with a borescope and check all valve guides, particularly the exhausts for corrosion and sticking. at least, if the storage period is significant. Nev Link to comment Share on other sites More sharing options...
coinz Posted April 5, 2014 Author Share Posted April 5, 2014 How long is a WHILE and was it inhibited? You can't just let motors sit and then fire them up and fly years later. You should pressurise the oil system before running and check cylinders with a borescope and check all valve guides, particularly the exhausts for corrosion and sticking. at least, if the storage period is significant. Nev Good point Nev,it could have been a number of years, will make a phone call.As to the pressurizing,that's a good idea too,i imagine that will require removing the oil filter and pumping oil through the outlet.Will report back how we go. colin Link to comment Share on other sites More sharing options...
facthunter Posted April 6, 2014 Share Posted April 6, 2014 You can use the tapping your oil pressure sender goes from. IF the engine is out of the plane you can put say a litre into the case and roll the engine around to distribute it to the pistons and cam lobes/followers, timing gears. Nev Link to comment Share on other sites More sharing options...
coinz Posted April 6, 2014 Author Share Posted April 6, 2014 We've now gone thru and got oil circulating,engine started and runs fine,but low compression on one cylinder,looks like we''l have to do a valve job all round.However the clicking noise is still there,even after the motor was run for 15 minutes.I'm now thinking it may be the magnetized alternator rotor,and clearance in the accessory drive gears moving back and forward.I realize there's basically no parts for these relic's from the past,does anyone know someone with KFM experience? cheers colin Link to comment Share on other sites More sharing options...
facthunter Posted April 6, 2014 Share Posted April 6, 2014 Check how much the engine is breathing. You may have a ring of rust in some bores and that could do bad things to the piston rings.. End float noises are usually intermittent not regular and are worse when hot. Nev Link to comment Share on other sites More sharing options...
coinz Posted April 6, 2014 Author Share Posted April 6, 2014 Check how much the engine is breathing. You may have a ring of rust in some bores and that could do bad things to the piston rings.. End float noises are usually intermittent not regular and are worse when hot. Nev thanks Nev,will pull one cylinder today if possible,looks like head and barrel are 1 piece, cheers colin Link to comment Share on other sites More sharing options...
facthunter Posted April 7, 2014 Share Posted April 7, 2014 Retension the studs that go through with spacers, before rotating the engine. Protect the cases from damage by the conrod dropping in it. (Just general advice). Nev Link to comment Share on other sites More sharing options...
coinz Posted April 12, 2014 Author Share Posted April 12, 2014 Retension the studs that go through with spacers, before rotating the engine. Protect the cases from damage by the conrod dropping in it. (Just general advice). Nev No worries Nev,haven't had a chance to get back onto it,and leaving for Wanaka monday so will be away few weeks,but the clicking is definitely not coming from the cylinders according to the stethoscope,and it's exactly the same hot or cold. colin Link to comment Share on other sites More sharing options...
coinz Posted May 12, 2014 Author Share Posted May 12, 2014 The mystery clicking of this type motor has been solved ,Rod from Jabaru says it is the "permanent magnets in the alternator and the gear drive of the alternator"the clicking transfers all the way through to the Prop.If there's no clicking then some thing is wrong. cheers colin 1 1 Link to comment Share on other sites More sharing options...
facthunter Posted May 12, 2014 Share Posted May 12, 2014 Just a matter of being familiar with a particular engines idiosynchrasises. Glad you identified it. Nev Link to comment Share on other sites More sharing options...
Blueadventures Posted May 13, 2014 Share Posted May 13, 2014 The mystery clicking of this type motor has been solved ,Rod from Jabaru says it is the "permanent magnets in the alternator and the gear drive of thealternator"the clicking transfers all the way through to the Prop.If there's no clicking then some thing is wrong. cheers colin Good news. What aircraft is the engine in? I'm in Mackay I'll keep a eye for you. Cheers Mike Link to comment Share on other sites More sharing options...
skellywelly Posted August 28, 2020 Share Posted August 28, 2020 @coinz Are you still running the KFM engine ? Cheers, Skelly. Link to comment Share on other sites More sharing options...
facthunter Posted August 29, 2020 Share Posted August 29, 2020 Rod Stiff would certainly be familiar with that engine as the first Jabiru's used it and when it went off the market no suitable engine was available so they built their own design from the ground up. Their first engines (1600 cc) had no replaceable bearings probably for lightness and simplicity.. Plenty of engines do that as an example the little FN 300cc 4 cylinder engines of 1904 of which thousands were made. Nev Link to comment Share on other sites More sharing options...
nomadpete Posted August 29, 2020 Share Posted August 29, 2020 You mean this Ind of FN? This one I snapped at our local hardware. The owner has ridden it back to visit the manufacturer in Belgium. Link to comment Share on other sites More sharing options...
pmccarthy Posted August 29, 2020 Share Posted August 29, 2020 You mean this Ind of FN? This one I snapped at our local hardware. The owner has ridden it back to visit the manufacturer in Belgium. I have the book he wrote about that trip. Link to comment Share on other sites More sharing options...
coinz Posted August 29, 2020 Author Share Posted August 29, 2020 @coinz Are you still running the KFM engine ? Cheers, Skelly. No ,but someone else is,i found the Pup a little cramped.Sold it with spare motor.They are around,in hangers,sheds.Best thing is advertise under "wanted". cheers 1 Link to comment Share on other sites More sharing options...
nomadpete Posted August 30, 2020 Share Posted August 30, 2020 I have the book he wrote about that trip. Sorry about my triple post. I had trouble attaching the picture, then had trouble deleting redundant posts. Yes, same FN. The bike now has a period wicker sidecar. Link to comment Share on other sites More sharing options...
Jabiru7252 Posted August 30, 2020 Share Posted August 30, 2020 Hi guys,engine is a KFM 112M ,hasn't been run for a while,only 300 hours.When turning the motor on the prop there's a clicking noise,somewhat like a impulse connection but more a clicking evenly spaced and not as loud as an impulse.It's there turning it either way,and there for the whole revolution.Evenly spaced,like every 5 degrees.Motor turns smoothly,no grating .It seems to be coming from the front. Any ideas before a complete teardown ? regards colin Have you had somebody else come and have a listen? Link to comment Share on other sites More sharing options...
