Enigma Posted November 20, 2017 Share Posted November 20, 2017 Vortex generators improve low speed airflow over the wing enhancing a wings performance in slow flight. A benefit of this is a lower stall speed, but at a much less advertised cost (usually) of less stall warning. Of greater benefit (in my opinion) is that the vortex generators improve the aileron authority deeper into the slow flight regime. I am interested in experimenting with vortex generators only affixed to the outboard section of the wings so as to enhance the low speed authority of the ailerons while leaving the inboard section of wing to stall at it's normal angle of attack. It seems likely that others may already have experimented with this idea and I am wondering if any information is available? I am especially curious if a second row of vortex generators closer to the ailerons has been experimented with and if it has proved to be beneficial or not? Also how far forward of the ailerons would a second row be placed to maximize aileron performance? Thank you. Link to post Share on other sites
djpacro Posted November 20, 2017 Share Posted November 20, 2017 They'll only improve aileron authority if there is any degradation in that authority due to separated flow so the first thing to do is to put tufts there and look at what is going on. 1 Link to post Share on other sites
JG3 Posted November 20, 2017 Share Posted November 20, 2017 [quote=Of greater benefit (in my opinion) is that the vortex generators improve the aileron authority deeper into the slow flight regime. I am interested in experimenting with vortex generators only affixed to the outboard section of the wings so as to enhance the low speed authority of the ailerons while leaving the inboard section of wing to stall at it's normal angle of attack. It seems likely that others may already have experimented with this idea and I am wondering if any information is available? I am especially curious if a second row of vortex generators closer to the ailerons has been experimented with and if it has proved to be beneficial or not? Thank you. Yes, VGs only in front of the ailerons has been tried many times and is effective in increasing aileron authority at lower speeds. Jabiru 200 series have particularly noticed this. There is unlikely any benefit placing a second row of VGs farther back near the aileron, due to the thickening boundary layer at that point. The vortexes once generated by the VGs at the front of the wing are very persistent and stream right back to the trailing edge. Link to post Share on other sites
SDQDI Posted November 20, 2017 Share Posted November 20, 2017 There was a huge thread on this site some time ago about vortex generators which would be worth a read. I will try and look it up in a minute. Leaving the middle section to stall is a thing that is done by quite a few different people. Just be careful if doing your own testing as while vg's can improve your planes performance they can also change it for the worse. for example your plane may have had a mild stall before vgs but after it may have a viscous wing drop which if unsuspected could cause trouble. What I am trying to say is just be prepared for these things. Having said that I have had only good experiences with them but that isn't always the case. 1 Link to post Share on other sites
SDQDI Posted November 20, 2017 Share Posted November 20, 2017 Do vortex generators really work. There is a couple of threads but this one would be a start Link to post Share on other sites
