red750 Posted April 19 Share Posted April 19 ATT00370.mp4 5 Link to comment Share on other sites More sharing options...
rgmwa Posted April 19 Share Posted April 19 Nice flying! Link to comment Share on other sites More sharing options...
spacesailor Posted April 19 Share Posted April 19 Is he a licenced ' sparky ' . LoL spacesailor Link to comment Share on other sites More sharing options...
IBob Posted April 19 Share Posted April 19 Astonishing arc as they leave at the end! I watched it several times, kept thinking I'd be really nervous that the red ground clamp he had on the cable could be knocked/pulled off during the procedure. Was the wrap he was putting on to stop the yoke thing from working it's way down the cables? If so, I'd say they are very much in need of some simpler quicker attachment. 1 Link to comment Share on other sites More sharing options...
kasper Posted April 20 Share Posted April 20 1 hour ago, IBob said: Astonishing arc as they leave at the end! I watched it several times, kept thinking I'd be really nervous that the red ground clamp he had on the cable could be knocked/pulled off during the procedure. Was the wrap he was putting on to stop the yoke thing from working it's way down the cables? If so, I'd say they are very much in need of some simpler quicker attachment. Hmmm. Out in the weather. Rainwater as an electrolyte. Out of sight for easy inspection. Lots of electricity. I say a simple same metal spiral clamp would be the best solution over any form of screwed clamp with different metals involved that has the perfect conditions to corrode and fail without warning. Link to comment Share on other sites More sharing options...
rgmwa Posted April 20 Share Posted April 20 Here's another one. Not my idea of a fun job or if you don't like heights. 3 Link to comment Share on other sites More sharing options...
nomadpete Posted April 20 Share Posted April 20 Here's another one - we also have live line workers in Australia, too. Link to comment Share on other sites More sharing options...
Geoff_H Posted April 25 Share Posted April 25 On 20/04/2022 at 10:06 AM, kasper said: Hmmm. Out in the weather. Rainwater as an electrolyte. Out of sight for easy inspection. Lots of electricity. I say a simple same metal spiral clamp would be the best solution over any form of screwed clamp The problem very high voltages is the corona discharge. Any sudden change of shape (eg bolts) will create an additional high voltage that can cause a discharge, between phases in this case. The mathematics of corona discharge is the same as a stress raiser on a rotating shaft. 1 1 Link to comment Share on other sites More sharing options...
kasper Posted April 25 Share Posted April 25 16 minutes ago, Geoff_H said: The problem very high voltages is the corona discharge. Any sudden change of shape (eg bolts) will create an additional high voltage that can cause a discharge, between phases in this case. The mathematics of corona discharge is the same as a stress raiser on a rotating shaft. One of the many reasons I try to play with high voltage as little as possible - I’m very good at following wiring diagrams and processes drafted by people who know what they are doing and what’s safe for me to do. 1 Link to comment Share on other sites More sharing options...
Geoff_H Posted April 25 Share Posted April 25 I actually commissioned the Eraring power station end of the first 500kV power line in Australia.. the scary thing is a 330/500kV switchyard on a wet dark night it crakles and sparks. I worked at Vales Point power station when we had 330kV current transformer explosions.... Very very scary. 1 1 Link to comment Share on other sites More sharing options...
nomadpete Posted April 25 Share Posted April 25 Digressing, but when the first of those CT's exploded in Qld, nobody knew why, but someone reported an increase in RF noise in their AM radio. So, I ended up wandering around HV switchyards nervously aimimg a alloy yagi antenna at CT's, looking for the rising RF that might indicate impending explosion. My apprentice followed me to carry the spectrum analyser. The engineer who thought this was a good idea, stayed in his cosy safe office. 1 Link to comment Share on other sites More sharing options...
Geoff_H Posted April 25 Share Posted April 25 I was an engineer but we used the same method to discover a faulty CT. We discovered the RF radiation after an operator said that now that a ct exploded that he could watch tv again... 1 Link to comment Share on other sites More sharing options...
nomadpete Posted April 26 Share Posted April 26 I forgive you, Geoff. On 25/04/2022 at 4:49 PM, Geoff_H said: I was an engineer 1 Link to comment Share on other sites More sharing options...
Geoff_H Posted April 26 Share Posted April 26 Thanks nomad. Much appreciated. I was misguided, but have seen the error of my way. Totally retired now..... well maybe not totally.. lol 1 1 Link to comment Share on other sites More sharing options...
