facthunter Posted August 31, 2023 Posted August 31, 2023 I would think so.. The Continental 0-200 was a very reliable motor, and a near new one still can be, THIS motor has a few better features. No good little radials yet? They are the best to supercharge. Nev
danny_galaga Posted September 1, 2023 Author Posted September 1, 2023 On 31/08/2023 at 11:23 PM, facthunter said: I would think so.. The Continental 0-200 was a very reliable motor, and a near new one still can be, THIS motor has a few better features. No good little radials yet? They are the best to supercharge. Nev Expand V8s supercharge quite nicely 🙂
facthunter Posted September 1, 2023 Posted September 1, 2023 They usually need two.. A radial will easily have equal length and short intakes and a dead easy drive from the accessories drive case at the back. Nev
BrendAn Posted September 2, 2023 Posted September 2, 2023 (edited) On 31/08/2023 at 11:23 PM, facthunter said: I would think so.. The Continental 0-200 was a very reliable motor, and a near new one still can be, THIS motor has a few better features. No good little radials yet? They are the best to supercharge. Nev Expand Aussie made. Reputation seems to be improving. Edited September 2, 2023 by BrendAn
BrendAn Posted September 2, 2023 Posted September 2, 2023 On 31/08/2023 at 11:23 PM, facthunter said: I would think so.. The Continental 0-200 was a very reliable motor, and a near new one still can be, THIS motor has a few better features. No good little radials yet? They are the best to supercharge. Nev Expand Don't forget the Verner either
danny_galaga Posted September 2, 2023 Author Posted September 2, 2023 On 01/09/2023 at 2:05 AM, facthunter said: They usually need two.. A radial will easily have equal length and short intakes and a dead easy drive from the accessories drive case at the back. Nev Expand Youve not looked too closely at a hot rod then. V seems nearly ideal for supercharging
skippydiesel Posted September 2, 2023 Posted September 2, 2023 On 07/08/2023 at 4:34 AM, RFguy said: mmmmm looks short on cooling surface area.-- but might be OK is the aluminium is the right type and cooling airflow done right. wonder how many bearings. nice big pots. (Lycoming) flywheel and prop together I like. (Lycoming) carb attached to sump etc and inlets I like (a la Lycoming) single carb I like. (Lycoming) maybe a hot upgrade for 2200 jabiru powered beasts ? HOWEVER not competitive with a 912..... so.... ????? Expand It must be a DUCK 😄
skippydiesel Posted September 2, 2023 Posted September 2, 2023 On 02/09/2023 at 10:32 AM, danny_galaga said: Youve not looked too closely at a hot rod then. V seems nearly ideal for supercharging Expand If they cant keep it within the engine bay of a car, what jhope for an aircraft🙃 2
Area-51 Posted September 2, 2023 Posted September 2, 2023 On 02/09/2023 at 8:12 AM, BrendAn said: Aussie made. Reputation seems to be improving. Expand 1 1 1
facthunter Posted September 3, 2023 Posted September 3, 2023 The usual way for V8's on a car is two . Assuming turbos as the hotrod set up is not practical for road use though some forms of it have been done nicely by clever engineers.. Nev
facthunter Posted September 3, 2023 Posted September 3, 2023 IF having lots of mainbearings is a must why is the 912 exempt from that requirement? Nev
danny_galaga Posted September 3, 2023 Author Posted September 3, 2023 On 02/09/2023 at 10:42 PM, skippydiesel said: If they cant keep it within the engine bay of a car, what jhope for an aircraft🙃 Expand I picked something deliberately lairy to make a point 😁 There are plenty of regular cars with mechanical superchargers nicely confined in the engine bay. Look at the Mercedes Kompressor range. 1 1
danny_galaga Posted September 3, 2023 Author Posted September 3, 2023 On 03/09/2023 at 12:35 AM, facthunter said: The usual way for V8's on a car is two . Assuming turbos as the hotrod set up is not practical for road use though some forms of it have been done nicely by clever engineers.. Nev Expand Most people assume a supercharger to mean mechanical, usually belt driven. And then a turbo supercharger is just referred to as a turbo. V8s in cars generally have ONE mechanical supercharger. The way the inlets sit inside the V lends itself to that configuration 1
facthunter Posted September 3, 2023 Posted September 3, 2023 I wouldn't describe it as PLENTY. There are a few .The majority are turbo and many of them Dual turbo. The LAG is what you try to get rid of. Nev
danny_galaga Posted September 3, 2023 Author Posted September 3, 2023 On 03/09/2023 at 2:01 AM, facthunter said: I wouldn't describe it as PLENTY. There are a few .The majority are turbo and many of them Dual turbo. The LAG is what you try to get rid of. Nev Expand No lag on a supercharger - that's why they use them for drag racing. Plenty or not, when you are on the road, and you see a Mercedes with a 'Kompressor' badge, it has a nice lil supercharger nestled quite neatly in the confines of the engine bay 🙂 1
facthunter Posted September 3, 2023 Posted September 3, 2023 Some of the Merc. ones are clutched. The drag ones are a positive displacement so no lag.. IF they backfire the whole thing goes up. Nev
danny_galaga Posted September 3, 2023 Author Posted September 3, 2023 My original statement was that V8s supercharge nicely. Nothing you are saying negates that 🙂 1
facthunter Posted September 3, 2023 Posted September 3, 2023 What does NICELY actually mean? The "drag " situation is only one very specialised application for a Rootes type blower. Aircraft which must have extra pressure when up higher are overwhelmingly radials with centrifugal gear driven blowers with a couple of turbocharged exceptions like the supercharged P&W R-1830s in the Liberators.. . Nev 1
Marty_d Posted September 3, 2023 Posted September 3, 2023 On 02/09/2023 at 11:30 PM, Area-51 said: Expand That wasn't a great advertisement for them. Where did he get the time though - built 2 planes then had to rebuild them both - I'm having trouble completing 1!! 1
facthunter Posted September 3, 2023 Posted September 3, 2023 They've had a few issues over the Years The later reduction gears are case hardened which is better than Nitriding. I think you might be able to do without the reduction gears on lighter models. It's got a great period look and sound. Part of the reason it was produced. Let's hope it can be sorted. Nev
onetrack Posted September 3, 2023 Posted September 3, 2023 The Verner radials are a clever piece of work, simply utilising Honda generator heads and VW cylinders and pistons. Repairs are much cheaper, thanks to the widespread availability of bits. Of course, you're never going to have a streamlined racer with a radial, but the exhaust note and the great vintage looks must count for something! https://opposite-lock.com/topic/28513/verner-radial-engines-the-art-of-sourcing-existing-things-to-make-new-things 1
BrendAn Posted September 3, 2023 Posted September 3, 2023 On 02/09/2023 at 11:30 PM, Area-51 said: Expand That's an old video. 1
BrendAn Posted September 3, 2023 Posted September 3, 2023 On 03/09/2023 at 6:32 AM, facthunter said: What does NICELY actually mean? The "drag " situation is only one very specialised application for a Rootes type blower. Aircraft which must have extra pressure when up higher are overwhelmingly radials with centrifugal gear driven blowers with a couple of turbocharged exceptions like the supercharged P&W R-1830s in the Liberators.. . Nev Expand I am confused. Are we talking about 2023 or 1945. 2
facthunter Posted September 3, 2023 Posted September 3, 2023 Well just what piston engines go high now? Virtually none..It's all turbine. You don't HAVE to play dumb.. I'm talking about when they did and still could on a smaller radial for those who might wish to consider it. It helps distribute the fuel evenly also which is a constant problem when Injection is not used. Nev 1 1
danny_galaga Posted September 4, 2023 Author Posted September 4, 2023 On 03/09/2023 at 10:18 AM, BrendAn said: I am confused. Are we talking about 2023 or 1945. Expand Facthunter wants to buy a Rotec radial, install a supercharger and then fly to 1945 😀 2
