danny_galaga Posted August 3, 2023 Share Posted August 3, 2023 (edited) This is ground up work, not a clone. Looks interesting 😎 Doesn't look like it will be cheaper than a 912, but interesting direct drive alternative for the home builders https://www.kitplanes.com/110-horsepower-taiwan-surprise/ Edited August 3, 2023 by danny_galaga 3 Link to comment Share on other sites More sharing options...
skippydiesel Posted August 3, 2023 Share Posted August 3, 2023 Yawn! Link to comment Share on other sites More sharing options...
Old Koreelah Posted August 3, 2023 Share Posted August 3, 2023 Looks good; if I was building, it would be on my shortlist. 1 1 Link to comment Share on other sites More sharing options...
danny_galaga Posted August 3, 2023 Author Share Posted August 3, 2023 I like that head and cylinder is cast in one piece. Potentially less to go wrong. 3 Link to comment Share on other sites More sharing options...
onetrack Posted August 3, 2023 Share Posted August 3, 2023 To me, it appears there's an inadequate level of cooling fins in the head area. Compare it with say, many other air-cooled engines, they have a very sizeable number of fins all over their heads. The bottom line is the combustion chamber is where the heat is being generated, so you need those big fins all around that area. http://www.enginehistory.org/Piston/ACEvolution/ModernCyl.jpg http://www.enginehistory.org/Piston/ACEvolution/ACA-40.jpg Link to comment Share on other sites More sharing options...
Old Koreelah Posted August 3, 2023 Share Posted August 3, 2023 That Taiwanese engine seems to have an alternator under the flywheel (thus concentrating all the innertia storage in one area) avoiding Jabiru’s “mistake” of having them at opposite ends of the crank. 1 2 Link to comment Share on other sites More sharing options...
facthunter Posted August 3, 2023 Share Posted August 3, 2023 Cylinder design similar to a Franklin. One piece eliminates a common problem. Thats the best starter arrangement there is and a belt driven alternator too. Direct drive too. Keep your eye on this one. Nev 1 1 Link to comment Share on other sites More sharing options...
Area-51 Posted August 3, 2023 Share Posted August 3, 2023 I'm just not excited. I used to be excited, but just can't seem to find the inspiration to get excited here. We still have not yet seen the 115hp 250cc multi cylinder honda enya aerosport motor come out of japan. And we are all still eagerly awaiting the 225hp single cylinder side valve DangDeng ductile iron motor to ship from north korea. Iran are refusing to release any of their rebadged stolen rotax rebirth units due to sanctions. And the soviets flatly continue to refuse to reconsider everything under 12000hp as an insult to aviation. Just not excited. Going out to the shed to listen to 2GB and play with the victa again. 2 Link to comment Share on other sites More sharing options...
rodgerc Posted August 3, 2023 Share Posted August 3, 2023 I’ll get interested when they have sold 10,000 units and half of them are past the 2,000h mark. Until then, it’s all marketing. 1 1 1 Link to comment Share on other sites More sharing options...
440032 Posted August 3, 2023 Share Posted August 3, 2023 From the website - "In recent years, the new crown pneumonia epidemic has shrouded, but our engines are not infected and continue to conduct various performance tests" I must say I especially like to have MY aircraft engines not infected with any virus. 1 Link to comment Share on other sites More sharing options...
skippydiesel Posted August 3, 2023 Share Posted August 3, 2023 So! what's new or differently applied technology, in this engine? Its price is attractive but so what, other engines are similarly priced. If it was liquid cooled, with variable ignition and overhead cam, driving the prop through a innovative gearbox, with an all up weight equal/better than the industry leader - then it might just be of some passing interest. 1 Link to comment Share on other sites More sharing options...
facthunter Posted August 3, 2023 Share Posted August 3, 2023 (edited) Pretty big condemnation from our team of experts . At least the exhaust ports have More finning than the Inlets and there's excellent heat flow through the entire Head/barrell connection being ONE piece. No pipes all over the place either and the fuel is below the engine with a better designed intake and there will be little trouble with carb icing It's power/weight is good and any gearbox is using power and is an extra liability and cost and with it, you cannot use the prop as a flywheel..Nev Edited August 4, 2023 by facthunter 1 1 1 Link to comment Share on other sites More sharing options...
facthunter Posted August 4, 2023 Share Posted August 4, 2023 ADD when it is geared. The aluminium is cast onto the iron like earlier Japanese 2 stroke triail bikes were and that "Joint" must persist or there will be distortion and hot spots. Those cylinders are probably done in metal dies which once made are cheap to produce in quantity and consistently. Sometimes referred to as Vacu-cast. Little or NO porosity, but the bores will NOT be hard as the aluminium pours at above red heat and anneals the iron. .Nev Link to comment Share on other sites More sharing options...
onetrack Posted August 4, 2023 Share Posted August 4, 2023 And the engine also reverts to 1930's engine design practice, with severe limitations placed on valve positioning, thanks to the one-piece cylinder and head. You can only position the valves directly in line with the cylinder in a setup like this, so the seats can be machined. That eliminates any ability to produce a better combustion chamber shape, such as a hemispherical chamber. The engine has no major technological advances over anything previously produced, and offers no gains in fuel economy, no multi-fuel abilities, no forced induction for improved efficiency - in fact, it's a pretty ho-hum engine, as Skippy says. Link to comment Share on other sites More sharing options...
facthunter Posted August 4, 2023 Share Posted August 4, 2023 (edited) Most radials have hemispherical heads and you can service the heads but it's more difficult. It also allows larger valves but in line motors don't have the space the radial configuration allows. Having a head joint is not desirable. It's a weakness. This typeof motoris easily able to be supercharged if the extra heat is able to be handled. Just because it resembles the look of a 30's motor doesn't mean it is NOT a lot better than many or all of them. It's in the metallurgy and cost control. It's not as if you have overwhelming numbers of good engines to pick from. There are far more failures than successes. in the modern AERO piston engine arena. Nev Edited August 4, 2023 by facthunter 1 Link to comment Share on other sites More sharing options...
onetrack Posted August 4, 2023 Share Posted August 4, 2023 (edited) Removing the head joint might have been desirable in the 1930's when cylinder-to-head sealing was a major problem area - but modern designs and materials have almost completely eliminated head gasket problems. Having the freedom to design a head with a vastly improved and more efficient layout and shape, and which is able to be quickly and easily removed to check for problems (and is easy to repair), is a big step forward from a one-piece cylinder and head. My prediction is that this engine won't even make a measurable dent in established light aircraft engine sales. It's not like it's got major cost advantages, either, it's still pricey for what it is. Edited August 4, 2023 by onetrack Link to comment Share on other sites More sharing options...
facthunter Posted August 4, 2023 Share Posted August 4, 2023 (edited) Being non mass produced makes this type of motor always dearer than others and if there's any issues it's headlines. You can't be serious about head sealing and heat flow The OLD 90 degree valve inclination is long gone. Too much head (combustion Chamber) area and the valves easily touch each other if one jambs. Flat top piston is least AREA ( heat )also. Nev Edited August 4, 2023 by facthunter Link to comment Share on other sites More sharing options...
Old Koreelah Posted August 4, 2023 Share Posted August 4, 2023 2 hours ago, facthunter said: … the valves easily touch each other if one jambs. Flat top piston is least AREA ( heat )also. Nev My RVR diesel stopped running after the cam chain broke. I removed the head, replaced chain, guide and gasket. Did not touch the head; the flat-topped pistons must have just punched the parallel valves with no damage. I put it back together and it ran for years afterwards. 1 Link to comment Share on other sites More sharing options...
facthunter Posted August 4, 2023 Share Posted August 4, 2023 You're a bit lucky to get away with that, Maybe the Valves were a bit pocketed A diesel head is usually just flat. Nev 2 Link to comment Share on other sites More sharing options...
Area-51 Posted August 4, 2023 Share Posted August 4, 2023 Screw all this, i'm relocating to an undisclosed pacific island atol with my freshly developed 125hp plutonium pico reactor powered stol lightwing and box of iced vovo's. 1 2 Link to comment Share on other sites More sharing options...
Blueadventures Posted August 4, 2023 Share Posted August 4, 2023 22 minutes ago, Area-51 said: Screw all this, i'm relocating to an undisclosed pacific island atol with my freshly developed 125hp plutonium pico reactor powered stol lightwing and box of iced vovo's. Take some TimTams as well for any necessary chocolate fix’s. 1 1 Link to comment Share on other sites More sharing options...
facthunter Posted August 4, 2023 Share Posted August 4, 2023 I think it's good that people still try to make a cheap reliable motor for us to have a larger choice.. Jabiru lost the KFM when the makers just stopped making it. Rotax have discontinued two of the three 2 stroke motors. It's not as if the problem will just go away. it's an ever changing situation.. Nev 2 1 Link to comment Share on other sites More sharing options...
RFguy Posted August 7, 2023 Share Posted August 7, 2023 (edited) mmmmm looks short on cooling surface area.-- but might be OK is the aluminium is the right type and cooling airflow done right. wonder how many bearings. nice big pots. (Lycoming) flywheel and prop together I like. (Lycoming) carb attached to sump etc and inlets I like (a la Lycoming) single carb I like. (Lycoming) maybe a hot upgrade for 2200 jabiru powered beasts ? HOWEVER not competitive with a 912..... so.... ????? Edited August 7, 2023 by RFguy 2 1 Link to comment Share on other sites More sharing options...
facthunter Posted August 7, 2023 Share Posted August 7, 2023 If only it was THAT simple. Nev 1 Link to comment Share on other sites More sharing options...
Flightrite Posted August 31, 2023 Share Posted August 31, 2023 If it shows decent reliability and is a compatible price then they’ll sell like hot cakes! 1 Link to comment Share on other sites More sharing options...
