Kenlsa Posted May 15 Share Posted May 15 Has anyone tried this style of reinforced baseball cap? My Colt now has a skylight with plenty of opportunity to extract some claret from the old melon. I don’t think I could get away with a dedicated helmet as the style of aircraft would initiate “Wan@er” calls but I should be able to get away with a toughened bb cap. Ken 1 Link to comment Share on other sites More sharing options...
facthunter Posted May 15 Share Posted May 15 Good for landing into the sunset (if you must) Have the seat set lower. You mustn't hit your head in turbulence with the seat belt tight. Nev 2 Link to comment Share on other sites More sharing options...
FlyBoy1960 Posted May 15 Share Posted May 15 I have used them in a cub clone and they work a TREAT ! Worth every cent 1 Link to comment Share on other sites More sharing options...
turboplanner Posted May 15 Share Posted May 15 Do some research on similar applications if you can find them. We have a good thread on here where we discussed it extending to ways of incorporating roll cages. Most race car designs are not quite right for aircraft because they are based on front end collisions, and roll overs/end over ends at several times per second, whereas the aircraft can hit a tree head on and a helmet helps there, but the aircraft's wings slow rotation in two planes. The most common flip over of a Jab is loss of control when landing nose down or flat and running off the runway where the resul can be a nose dig on and graceful tip over the nose where that cap may well help with knocks. The other factor in an aircraft is the need for rapid head movements to full neck capacity, where that cap would work but an open-face or full helmet wouldn't. The cap helmet makes radio a non-issue where a full helmet needs to be extende to avoid punching a cigarette pack size hole in your skull. All in all a lot of pluses there. Horse riders have pretty much the same needs, so a comparison between performances might show up something to work on. 1 Link to comment Share on other sites More sharing options...
440032 Posted May 15 Share Posted May 15 They are meant to stop you banging your head on hard car bits when it's up on the hoist. I used one at work after about the sixth towbar/spring shackle hit. The downside for that use is the front visor peak, it blocks your upward view and BANG! (and to that some say Ahhhh! That explains a lot.) I fly with a Gallet helmet in my plane, and when backseating in Harvard or L39 with a mate. 1 Link to comment Share on other sites More sharing options...
spenaroo Posted May 15 Share Posted May 15 I have one of these in my helmet collection. might do the job (was bought back from Vietnam for me - where they are used as motorcycle helmets) 1 Link to comment Share on other sites More sharing options...
Freizeitpilot Posted May 15 Share Posted May 15 In industry they are called ‘bump hats’ as opposed to hard hats. Any PPE store should have them if you are looking for different options. 1 Link to comment Share on other sites More sharing options...
Marty_d Posted May 16 Share Posted May 16 Here you go. May not stop the W calls though. https://www.skyshop.com.au/shopexd.asp?id=1534 1 2 Link to comment Share on other sites More sharing options...
spacesailor Posted May 16 Share Posted May 16 A quality bicycle helmet ! . Not so good in a high-speed crash . but, OK in ' bump your head ' . spacesailor 1 Link to comment Share on other sites More sharing options...
Litespeed Posted May 16 Share Posted May 16 Just buy a quality open face helmet, no better protection and a fine field of view And never ever strap a camera to it. Not helmets are made the same. How much is your brain worth? Link to comment Share on other sites More sharing options...
spacesailor Posted May 16 Share Posted May 16 " How much is your brain worth " . If I had a brain , I would have a ' flying certificate ' . spacesailor 1 Link to comment Share on other sites More sharing options...
