BrendAn Posted yesterday at 01:12 PM Posted yesterday at 01:12 PM my fuel drain valve drips after i do a fuel check. do i have to replace it or just change an o ring. i have never looked at one before but in pictures it looks like there is an o ring on the end of it.
spacesailor Posted yesterday at 01:38 PM Posted yesterday at 01:38 PM Try an " auto electrician " who does fuel injection. He will have the right size " Oring " . I purchased a new valve but received the wrong type & couldn't get a replacement! . spacesailor 1
onetrack Posted yesterday at 03:11 PM Posted yesterday at 03:11 PM Aircraft Spruce says they should be replaced, not repaired. Curtis Pipe Thread Drain Valve - CCA-1650 | Aircraft Spruce Australia WWW.AIRCRAFTSPRUCE.COM.AU Curtis Pipe Thread Drain Valve - CCA-1650 Quick opening brass drain valve for aircraft oil or fuel systems. A slight twist opens valve. 1
Thruster88 Posted 23 hours ago Posted 23 hours ago You can replace the oring. Need to obtain correct one from an aircraft maintenance organisation. If you choose to replace the valve then you need the correct thread, there are several similar looking threads in use. Take your valve to the your value to the maintenance shop and they will advise. 1 3
Blueadventures Posted 22 hours ago Posted 22 hours ago I reckon best to replace the valve with a new one. I carry two small size O rings as temporary repair in my spares kit but the seal is a square o ring shape. You can buy them ex USA, but best just get a new whole item. 1 1
skippydiesel Posted 21 hours ago Posted 21 hours ago Just curious, what might the cost (in AU) be of: The correct "O" ring ? Replacing the whole unit ? 😈
spacesailor Posted 20 hours ago Posted 20 hours ago I could say ! . Curtis sent me the wrong one , so no good , & expensive . The oring free from my local " fuel injection " shop . & working good ! . The different thread ! , straight or tapered . spacesailor 1 1
facthunter Posted 14 hours ago Posted 14 hours ago I don't like the idea of having an "O" ring there anyhow.. IF it's not there, It can't fail .Nev
jetboy Posted 12 hours ago Posted 12 hours ago It may just need to be cleaned, buy 1 new one and work on the leaky one as a spare. I'm amazed the other brand used for wing tanks are plated steel and that type once rust had started were not fixable. Who'd have thought to use steel as the best material for parts that are sliding together and their one job is to collect water ready for draining. I changed to the all SS version no more issues but for the other locations I use those brass Curtis and they are the best. The rubber is important for preventing the metal parts from snapping together and on some designs this is enough to break the retainer off and loose the plunger. 1 1 1
Thruster88 Posted 12 hours ago Posted 12 hours ago 2 hours ago, facthunter said: I don't like the idea of having an "O" ring there anyhow.. IF it's not there, It can't fail .Nev The O ring is what does the sealing. 1
Blueadventures Posted 12 hours ago Posted 12 hours ago (edited) . Edited 12 hours ago by Blueadventures
BrendAn Posted 11 hours ago Author Posted 11 hours ago 20 minutes ago, facthunter said: I don't like THAT design. . Nev You must have had them in your planes
Area-51 Posted 9 hours ago Posted 9 hours ago Curtis Valve; Viton O'ring; Ebay; Brown or Green spec; order 10, use 1, store the rest in a safe place that you know you will forget and never be able to find them again. 1 1
onetrack Posted 9 hours ago Posted 9 hours ago I second Area-51, the brown and green Viton o-rings are exceptionally durable. I keep them in a PVC ziplock bag in the top sliding drawer of my toolbox - where you always know where they are, because you have to shove them aside, to get the tools out. 😄 1 1
