Message added by robinsm,
Chat GPT content deleted,  Mod
Beachcombers will the ones that will find anything. Something will turn up eventually.
Anyone know if this Bristell was fitted with the optional BRS chute?
On 4/8/2025 at 5:17 PM, onetrack said:
Then there's the fact that the Bristell has some serious handling issues, and the owner has only owned it a short time, and perhaps may have not been fully conversant with the Bristells "issues".
And finally, the Bristell is available with a BRS, but it seems this aircraft wasn't fitted with one.
Serious handling issues??  And you have proof of this information where?
I’ve owned and flown one for 5 years mate. There’s no “serious” issue that I know of, or have ever experienced, so I’m curious on your statement.
Care to elaborate??
Yep - Quote from the ATSB crash report below....
"The Bristell exhibits different handling characteristics to the other aircraft type the student pilot had previously operated. Specifically, instructors reported that it is less docile and has a stronger tendency to pitch up when engine power is applied for a go-around.
The instructors also reported that the Bristell has less elevator authority to counter the nose-up effect and a greater tendency to drop a wing (usually the left) during a stall."
Another quote from a different ATSB crash report below....
"Following a number of fatal accidents involving Bristell aircraft entering into and not recovering from spins in Australia and overseas, CASA assessed the Bristell LSA self-certification testing documentation against the ASTM certification test standards.
CASA found that there was insufficient information in the initial test data to provide assurance that the aircraft type met the ASTM standards for spin recovery. As a result, CASA requested more certification testing data from the manufacturer.
The manufacturer conducted further certification flight tests in the Bristell LSA and provided that data, including video recordings of each flight sequence to CASA.
CASA’s assessment of the new flight testing data and further information supplied by the manufacturer was that it still did not confirm that the aircraft met the required ASTM standard for spin recovery."
https://www.atsb.gov.au/sites/default/files/media/5778172/ao-2018-066_final.pdf
it is so funny how the owner of an aircraft gets so defensive when somebody brings up factual information about an engine or handling issue of that particular breed
My friend who had a Bristell says that the transponder came on automatically at a certain airspeed. So if it did not come on, it must be a deliberate switch off or an electrical failure. Perhaps a master switch or isolator bumped off during preflight checks?
You probably missed the saga prior to your 5 years with it?
Much happened after that. I was following it all but I'm sure I don't know the whole story.
Some years ago, one of my friends sought a dual flight in a Bristell at a flight school. He was told they didn’t do stalls in them! A year or so later a CASA examiner told me that pilots were presenting themselves for flight tests in Bristells and refusing to stall them for the test. Why was that? I spoke to some Bristell flight instructors.
In 2020, CASA issued a safety notice for flight schools operating Bristells which “prohibited from conducting an intentional stall of the aircraft, or from performing any flight training activities that could reasonably lead to an unintended stall …”
CASA  then “sought confirmation from the manufacturer as to compliance with the ASTM LSA standards and, in particular, spin compliance flight testing. At the present time, CASA has not received sufficient assurance as to the extent of such testing, including testing covering each design variant.” It seemed to me that BRM had shown compliance with the spin requirements (I reviewed the reports) but CASA was stuck on the thought that it must not comply because of the spin accidents but unable to identify any specific issues with the test reports.
Then we got some independent flight tests of an in-service aeroplane with questions as to the conformity of the particular aeroplane and conduct of the tests. All a little murky as to who authorised these tests. Certainly not CASA.
I did a W&B calculation from the data in the manual. Two people at 90 kg each right on the aft limit. Then there was another airworthiness alert! The crew moment arm in the manual was incorrect. W&B section of the manual was rewritten to make comparisons difficult. The same two 90 kg people now put the CG way way behind the aft limit!
Aeroplanes were reweighed and ballast added firewall forward to move the empty CG forward. Moving the CG forward has a beneficial effect on handling characteristics, especially stalling and spinning.
All the issues seemed to disappear overnight. No more said that I am aware of. The whole saga certainly showed the incompetence of some at the factory, RAA and CASA. Some at the regulatory authority especially were out of their depth.
  • Informative 5
From what I was told (airport gossip) everything went quiet because the importer in Australia started legal action against everybody (RA-Aus and CASA) once this happened everything was dropped like a sack of potatoes...
That too.
3 hours ago, facthunter said:
ANY plane becomes a death trap if the Cof G is too far Back. EVERY Pilot should KNOW that. It's BASIC.  Nev
Yes, but the wrong crew moment arm was in the manual so the pilots did not know their CG was further back.
You can tell by where the Elevator sits in flight and the stick will be forward and elevator down.. With a tail dragger the rear will be reluctant to lift off the ground on take-off roll.  You should ABORT IF that is the case. With a tricycle gear the Nosewheel won't have enough weight on it and will rotate too easily if trim is normal and want to go to a high nose up pitch..
  Having the Book wrong is inexcusable but the Pilot should be alert for anything that is NOT Normal and be ready to STAY on the ground.. Nev
LOL!  Nothing about being defensive, and for the record, I know just about everything about every fatal incident the Bristell has ever been involved in.  So how long have you got?
So let's look at what you posted shall we...
"The Bristell exhibits different handling characteristics to the other aircraft type the student pilot had previously operated"  What part of that gives it serious issues?  The incident you speak of was an inexperienced pilot, that had no business being in the cockpit in the first place - Nothing to do with the aircraft!   He had zero experience with it.
Next one...
The report you have quoted, has now also been sorted - otherwise, if they did not meet the standard, they would be off the market.  The aircraft has now been proven to spin recover.  (there is video if you have 5 minutes, not hard to find)
Now the tendency to drop a wing... How many do that at stall!  LOL!  My Sportstar did that!  Sheesh!
Facts? - LOL!  That's funny!
I am not being a defensive aircraft owner, but if you are going to speak facts, then make sure you get the facts right, or you just look silly.
Yep!  100%. The Datum issue was a real problem, and yes, someone at the factory has a lot to answer to.  The CoG of the Bristells are tight - no doubt about it.  I am lucky, myself and my wife are lightweights, so we don't have an issue.  I would hate to have a couple that are 100kg each.   But then, the Bristell is no the airplane for them.
I have had my machine re-weighted and balanced by a CASA Auth, and made sure all my numbers are correct.  After the debacle with the data, I wanted to know.  Because we are light, I am able to add weight forward of the firewall, and removed the sleeper from the rear, so now I have a nicely balanced machine.
For the record, I have stalled my own Bristell, and was requested to do so on my last BFR (Not my Bristell) and it does what just about every other aircraft in its class does.  No surprises.
Edited by BirdDog
I did most of my training in the Evektor Harmony and found it very benign in a stall, not that I knew any different as I'm only a student with my limited previous experience flying my microlight unlicensed.
When the Harmony had it's engine change I briefly swapped to the Bristell. One thing I noticed on the pre-flight check was a big chunk of steel bolted to the gearbox, obviously a counterweight. Once in the plane my instructor informed me that we would be careful to avoid stalls. He said if we stall this plane we're not coming home, there's very little chance of stall recovery.
I guess for those couple of days he was very careful to monitor my performance on take-off and landing.
The bottom line is, no matter how much anyone claims the Bristell is a perfect machine with zero faults, its safety record shows otherwise.
And at this point, we have another crashed Bristell, to add to the list of crashed Bristells here - and we have no knowledge of what happened, and are not likely to find out.
But the bottom line is, a virtually new factory-built aircraft, piloted by a gentleman with excellent piloting skills, left an airstrip with zero communication of any kind (in itself, utterly baffling) and totally disappeared without a trace. And no-one has discovered what happened with the Bristell that crashed and burnt right out at Redesdale in Victoria.
Finally, we are only currently talking about Bristell crashes in Australia, there have been a serious number of Bristell crashes in other countries.
That's what I would expect. However prior to the correction of crew moment arm the factory manual showed 2 people on board at 90 kg each being OK - without that forward ballast I would expect a quite different behaviour.
To illustrate:
With a too far AFT CofG the Tailplane can/will stall and you can't get the nose down and the Plane itself then stalls and it's all over. You MIGHT Manage to stay flying IF you keep the speed High. Its THE most dangerous situation for loss of control you are likely to encounter. You get into an Unrecoverable FLAT spin.   Nev
