red750 Posted May 3, 2018 Share Posted May 3, 2018 There were various versions of the Argus, one with the inline Ranger engine, as above, and others with the radial Warner engine. Next up: Link to comment Share on other sites More sharing options...
derekliston Posted May 3, 2018 Share Posted May 3, 2018 There were various versions of the Argus, one with the inline Ranger engine, as above, and others with the radial Warner engine.Next up: [ATTACH=full]55008[/ATTACH] Got lucky with the Argus. Worked on a Ranger engined one at Personal Plane Services at Booker many years ago. Never flew it nor flew in it, but did get to taxi it and do an engine run. No idea on the current one yet! Link to comment Share on other sites More sharing options...
Rastus Posted May 3, 2018 Share Posted May 3, 2018 There were various versions of the Argus, one with the inline Ranger engine, as above, and others with the radial Warner engine.Next up: [ATTACH=full]55008[/ATTACH] Savage Classic Link to comment Share on other sites More sharing options...
red750 Posted May 3, 2018 Share Posted May 3, 2018 I'll accept that, although you left out the maker, Zlin. - Zlin Savage was what I was looking for. Link to comment Share on other sites More sharing options...
red750 Posted May 5, 2018 Share Posted May 5, 2018 Lousy fishing - 36 hours and not a nibble. Wrong bait? Link to comment Share on other sites More sharing options...
Roundsounds Posted May 5, 2018 Share Posted May 5, 2018 Looks like it’s fitted with a Walter engine, a Zlin? Link to comment Share on other sites More sharing options...
red750 Posted May 5, 2018 Share Posted May 5, 2018 You're right about the engine, but not a Zlin. Link to comment Share on other sites More sharing options...
Roundsounds Posted May 5, 2018 Share Posted May 5, 2018 A Bucker or Messerschmitt? Link to comment Share on other sites More sharing options...
red750 Posted May 5, 2018 Share Posted May 5, 2018 Link to comment Share on other sites More sharing options...
Roundsounds Posted May 5, 2018 Share Posted May 5, 2018 I retract the Messerschmitt and Bucker. It’s a Mráz Sokol of some sort. M1D ? Link to comment Share on other sites More sharing options...
red750 Posted May 5, 2018 Share Posted May 5, 2018 Correct. M1c. A slight deviation from the thread. The Sokol (Eng: Falcon) was made by Benez Marx in Czechoslovakia after WWII. Another Czechoslovakian aircraft, the L-40 Meta Sokol, was somewhat similar but the vertical stabiliser had straight edges instead of curved. It was a 4 place retractable. It had two unusual features. It had an inverted tricycle undercarriage, in that the main gear was in line with the wing leading edge, and the third wheel was in line with the trailing edge. When retracted, part of the main gear protruded from the well so that in the event of a wheels up landing, the belly of the plane did not touch the ground. See photos below. Link to comment Share on other sites More sharing options...
red750 Posted May 5, 2018 Share Posted May 5, 2018 Here's the next puzzle image. Link to comment Share on other sites More sharing options...
Roundsounds Posted May 5, 2018 Share Posted May 5, 2018 Correct. M1c.A slight deviation from the thread. The Sokol (Eng: Falcon) was made by Benez Marx in Czechoslovakia after WWII. Another Czechoslovakian aircraft, the L-40 Meta Sokol, was somewhat similar but the vertical stabiliser had straight edges instead of curved. It was a 4 place retractable. It had two unusual features. It had an inverted tricycle undercarriage, in that the main gear was in line with the wing leading edge, and the third wheel was in line with the trailing edge. When retracted, part of the main gear protruded from the well so that in the event of a wheels up landing, the belly of the plane did not touch the ground. See photos below. [ATTACH]38039.IPB[/ATTACH] [ATTACH]38040.IPB[/ATTACH] My dad flew a Metal Sokol, he said it was a nice aeroplane to fly and couldn’t feel the difference with the reverse tricycle gear. It had a supercharger you could select on/off manually. Link to comment Share on other sites More sharing options...
Roundsounds Posted May 5, 2018 Share Posted May 5, 2018 Procaer F.15A Picchio? Link to comment Share on other sites More sharing options...
red750 Posted May 5, 2018 Share Posted May 5, 2018 Procaer F.15A Picchio? While they are quite similar, the window shapes and sizes are slightly different, but the main difference is the horizontal stabiliser on the one above has it's leading edge ahead of the fin, whereas the F-15A has it's leading edge well behind the fin. I featured the F.15A about 55 planes ago. Link to comment Share on other sites More sharing options...
Thruster88 Posted May 7, 2018 Share Posted May 7, 2018 Ruschmeyer R90 Link to comment Share on other sites More sharing options...
red750 Posted May 7, 2018 Share Posted May 7, 2018 That's the one. And now: Link to comment Share on other sites More sharing options...
Roundsounds Posted May 7, 2018 Share Posted May 7, 2018 There are aspects that look like Maule (fun/rudder, Wing tips, struts). Link to comment Share on other sites More sharing options...
red750 Posted May 7, 2018 Share Posted May 7, 2018 Not a Maule. Link to comment Share on other sites More sharing options...
Thruster88 Posted May 7, 2018 Share Posted May 7, 2018 Has to be a homebuilt Lyc 540 power composite wing? Link to comment Share on other sites More sharing options...
red750 Posted May 7, 2018 Share Posted May 7, 2018 Sold in kitform. Link to comment Share on other sites More sharing options...
SilverHammer Posted May 7, 2018 Share Posted May 7, 2018 Comp Air 6? Link to comment Share on other sites More sharing options...
red750 Posted May 7, 2018 Share Posted May 7, 2018 Yes SH. Link to comment Share on other sites More sharing options...
Thruster88 Posted May 7, 2018 Share Posted May 7, 2018 Eurofox sold in the USA as Aerotek A220 Link to comment Share on other sites More sharing options...
red750 Posted May 7, 2018 Share Posted May 7, 2018 Close enough. The Canadian register has it listed as Aeropro rather than Aerotek, but the model is A220. Link to comment Share on other sites More sharing options...
