facthunter Posted June 8, 2015 Posted June 8, 2015 I flew a 150 with an 0-320 in it and bigger tanks with them. There was a lot of info about fuel caps being left off and the bladder collapses with some Cessna's. The fuel indicator float rises and indicates fuel erroneously. I don't know which models. Nev
David Isaac Posted June 8, 2015 Author Posted June 8, 2015 Quote I flew a 150 with an 0-320 in it and bigger tanks with them. There was a lot of info about fuel caps being left off and the bladder collapses with some Cessna's. The fuel indicator float rises and indicates fuel erroneously. I don't know which models. Nev That would be a great short field performer Nev, especially if it still had the 40 degree flap capability.
djpacro Posted June 8, 2015 Posted June 8, 2015 I saw one at Moorabbin many years ago - payload reduced by the heavier engine and no change in MTOW so just a single-seater - it was converted back.
Guest ozzie Posted June 8, 2015 Posted June 8, 2015 Quote That would be a great short field performer Nev, especially if it still had the 40 degree flap capability. If you fly out of places like Colorado the extra HP would be a benefit. When bladders start to suck up or wrinkle the reduced capacity is more a worry than incorrect indication by gauges. (who believes them anyway).
old man emu Posted June 8, 2015 Posted June 8, 2015 Quote He spelt it right, just had the wrong right. And two Whites don't make a Wong. OME
facthunter Posted June 9, 2015 Posted June 9, 2015 Quick to get airborne Not a lot of prop ground clearance Had to keep the stick back taxying in rough. Got sold to be used for cattle rounding up. Nev
Guest ozzie Posted June 9, 2015 Posted June 9, 2015 The bigger engine and longer prop is more suited for use with the tail drager mod.
Guest ozzie Posted June 9, 2015 Posted June 9, 2015 Bummer! http://www.dailytelegraph.com.au/newslocal/central-coast/plane-ironic-berkeley-vale-pilot-had-just-won-a-forced-landing-award-before-crashing-on-way-home/story-fngr8h0p-1227388445511
jetjr Posted June 9, 2015 Posted June 9, 2015 Full marks to aero club chief and pilot with media management too. Both in the media inc tv saying what a sucesssful landing it was. Doesnt give journalists anywhere to go. 2
kaz3g Posted June 9, 2015 Posted June 9, 2015 Quote If you know the right rite, you might get to write about it. Nev That would be the last rite, Nev? Kaz
dazza 38 Posted June 9, 2015 Posted June 9, 2015 For clarity, the pilot's name is Paul Bennet as mentioned in previous posts , but he isn't the Paul Bennet aerobatic pilot. 1
David Isaac Posted June 9, 2015 Author Posted June 9, 2015 I know both of them, and this Paul Bennet is really well known to me.
Teckair Posted June 9, 2015 Posted June 9, 2015 Releasing your seat belt when you are hanging upside down sounds a bit risky, what do you do? try to support your weight with one hand release the belt with your other and try to roll out of the opened door?
SDQDI Posted June 9, 2015 Posted June 9, 2015 Quote Releasing your seat belt when you are hanging upside down sounds a bit risky, what do you do? try to support your weight with one hand release the belt with your other and try to roll out of the opened door? That's a very good question Teck. In my few years in our local rescue squad we haven't had to release someone who was upside down. Generally people who are upside down have been released by well meaning folk already on the scene and I know of at least one in our area who ended up with spinal injuries as a result of being released without anyone thinking to take the weight. As for releasing yourself, obviously adrenaline would be pretty high so you probably wouldn't think about it until after your head connected the roof, as the desire to get out would be extreme. Maybe some harnesses could be loosened to allow you to 'climb' down but most that I have seen wouldn't be able to be loosened easily while they have weight on them. 1 1
Guest Maj Millard Posted June 9, 2015 Posted June 9, 2015 I always mention this to my passengers when I brief them prior to flying with me in the Lightwing. I tell them being a taildragger worse case scenero would be we could end up on our back. if that occurres don't release your seatbelt until you take your weight otherwise you could break your neck when you hit the ceiling !....Most accept it well as part of the brief.
Teckair Posted June 9, 2015 Posted June 9, 2015 If there are two in the side by side plane and you end up side down maybe the procedure could be this, open doors, get the passenger to support them self with both hands, undo their seat belt and push them out the door. Once the passenger is free you support your self with both hands and get them to undo your seat belt and push you out the door. Might work?
REastwood Posted June 9, 2015 Posted June 9, 2015 When you go upside-down, the disorientation confuses you for a short while but I found I couldn't actually release my seatbelt in the J230 until I relieved the pressure by pushing with my legs. It took me about a minute to sort out up from down and which way to push, I'm very glad that there was no fire! 1 2
Keenaviator Posted June 9, 2015 Posted June 9, 2015 At least in a high wing aircraft it is an option. 1
David Isaac Posted June 9, 2015 Author Posted June 9, 2015 That you may not have in some low wing bubble canopy types. 1
red750 Posted June 9, 2015 Posted June 9, 2015 If the high wing folds towards the u/c, would this not obstruct the door from opening?
Teckair Posted June 9, 2015 Posted June 9, 2015 Quote I found I couldn't actually release my seatbelt in the J230 until I relieved the pressure by pushing with my legs. I am not understanding how that worked how did you prevent falling on your head?
Teckair Posted June 9, 2015 Posted June 9, 2015 Quote If the high wing folds towards the u/c, would this not obstruct the door from opening? It depends on how the door opens, on a Lightwing it lifts up.
David Isaac Posted June 10, 2015 Author Posted June 10, 2015 Quote If the high wing folds towards the u/c, would this not obstruct the door from opening? Maybe but there are typically two doors one on either side; less likely to collapse both wings onto each side of the fuselage.
turboplanner Posted June 10, 2015 Posted June 10, 2015 Quote When you go upside-down, the disorientation confuses you for a short while but I found I couldn't actually release my seatbelt in the J230 until I relieved the pressure by pushing with my legs. It took me about a minute to sort out up from down and which way to push, I'm very glad that there was no fire! I agree about the confusion, although mine was on a tractor. Nothing works the same with reverse gravity; it's amazing how much you rely on your bum against the seat back in order to push your legs, and push up with your arms when you're upright. That all goes when you're belly up and you have to think your way out. I'm very strong on pre-programming your mind for expected emergencies so your reaction is automatic, but these upside down events all seem to be different. 1
Mick Posted June 10, 2015 Posted June 10, 2015 Quote I found I couldn't actually release my seatbelt in the J230 until I relieved the pressure This is something that should be checked as part of any 50 / 100 hour / annual service. Easy to do, clip the harness, pull on the harness as hard as you can with one hand and release the latch with the other hand. If it does not release you have a problem. This is not something anyone wants to find out when hanging in a harness and needing to get out in a hurry. 1
