derekliston Posted February 28, 2021 Posted February 28, 2021 On 28/02/2021 at 2:15 AM, kasper said: Not only 10. Over 20 of them. The 10 was the modified ju87 with jettisoning fixed gear. to help - 26 in total built. next clue tomorrow Can only find the Edgley Optica but 23 of them built apparently. No idea about jettisonable undercarriage though! Expand
pmccarthy Posted February 28, 2021 Posted February 28, 2021 Thinks... must have been a fixed gear aircraft that was expected to spend a lot of time over water. Post war, so slow heavy lifter? Hmmm
facthunter Posted February 28, 2021 Posted February 28, 2021 Explains why it confounded us for so long. You wouldn't particularly want a short anything if the normal one was available. Nev 1
Garfly Posted February 28, 2021 Posted February 28, 2021 But you'd have to walk miles to find something more ungainly.
kasper Posted February 28, 2021 Posted February 28, 2021 (edited) Well done. Yes. The short seamew. A plane design hit repeatedly with the ugly stick and then given half the power it needed. Whack a double mamba in the front and I think it would have had half a chance in its role Edited February 28, 2021 by kasper
derekliston Posted February 28, 2021 Posted February 28, 2021 What is more annoying is that there is another post on here about the Seamew and Airtruk!!! Yet nobody picked it before pmccarthy! Well done that man. 1
pmccarthy Posted March 1, 2021 Posted March 1, 2021 Supposed to be capable of 18 hours endurance but at 75mph and took an hour to climb to 10,000 feet. Designed to defend England from Zeppelins, it was a failure.
red750 Posted April 6, 2021 Posted April 6, 2021 Another one without a photo. What helicopter had two angled tail rotors?
pmccarthy Posted April 6, 2021 Posted April 6, 2021 (edited) Boeing AH-64 Apache Edited April 6, 2021 by pmccarthy
red750 Posted April 6, 2021 Posted April 6, 2021 The desccription of the Apache's tail rotor I have seen is simply a 4 blade tail rotor. Although the two pairs of blades are not at right angles, they appear to be to one unit and do not counter-rotate. The machine in question has separate tail rotors at the end of two Vee shaped booms. I believe the odd spacing of the Apache's tail rotor reduces noise, similar to the odd blade spacing on some fenestrons.
red750 Posted April 6, 2021 Posted April 6, 2021 This is a photo of the S-56. It looks nothing like the image above. This aircraft is from around the same era, but is European. It was later modified to a conventional single tail rotor.
pmccarthy Posted April 7, 2021 Posted April 7, 2021 The caption on this photo says it was an early experimental version of the S-56 but the caption may be wrong. I will keep looking. 🙂
pmccarthy Posted April 7, 2021 Posted April 7, 2021 The very first Sikorsky also had twin tail rotors. But it is not the one you are thinking of.
red750 Posted April 7, 2021 Posted April 7, 2021 Let's put this to rest. The machine I came across was a SNCASE SE-3110 or Sud-Est SE-3110, a French two seat experimental helicopter with unusual twin, angled tail rotors, first flown in 1950. After brief tests SNCASE decided to concentrate on a closely related but single-tail-rotor design.
Student Pilot Posted April 10, 2021 Posted April 10, 2021 (edited) Spanish built Hispano Battle of Britten star Buchan? Edited April 10, 2021 by Student Pilot
red750 Posted April 10, 2021 Posted April 10, 2021 Yep. The way to spot the difference from the Bf-109 is the higher placement of the exhausts, like the Spitfire. Bf-109 exhausts are below the propeller drive shaft.
kasper Posted April 10, 2021 Posted April 10, 2021 Can’t remember it’s name but I read about it years ago. It’s an American one off experimental built to be a flying caravan/home for a retired guy and his wife. But it was under powered when complete and he was losing interest in it. Was somewhere down south in the USA - can’t recall if it was Florida or Georgia. .
red750 Posted April 10, 2021 Posted April 10, 2021 Yes. Wilson Global Explorer. Sleeping accommodation for 7 persons. Was retired after flying from Australia to France in 1998. A smaller, single engine version, Global Explorer 2 was also built.
