Roundsounds
  1. It’s good to see the Head of Safety reporting lines now reflect best practice.
  2. Are you sure none of the operating crew had appropriate experience? Even the best of professional teams come together on occasions.
  3. Stalls / spins are just another manoeuvre, you need to be competent at recognising the onset and recovering before they develop. You also need to be competent at recovering from developed stalls / spins. Again I reinforce the need not to fear these manoeuvres, but respect them. At no time did I insult your instructor, my comment was a general one around how stall / spin training is conducted today and supported by accident stats.
  4. If any type of stall scares the hell out of you, you need to find a competent instructor to help you get over the fear. Takeoff and landing are far more risky manoeuvres than stalls at a safe height. I reckon the fear of stalling rubs off from instructors who also have a fear of stalling / spinning.
  5. I was taught to add 500’ to the highest terrain 5NM either side of the planned track as a rule of thumb LSALT. This helps in go / no go decision making if the weather deteriorates. The sole reliance on devices for planning reduces familiarisation with route terrain.
  6. You’re quite correct regarding the limit of 250KIAS below 10,000’. A heavy jet on departure may need to exceed 250 to fly with flaps retracted and ATC can approve the exceedance. ATC may also approve high speed ops below 10,000 if requested by the crew.
  7. There seems to be an increase in mid air collisions in Australia. The most recent event cannot be treated the same as the other events due to the formation aspect. It seems as new technology emerges, so do the number of airprox events. I suspect pilots have lost / not being taught situational awareness skills.
  8. Many possible causes… https://www.atsb.gov.au/publications/occurrence-briefs/2018/aviation/ab-2018-124
  9. Stall warnings systems in many light aircraft are inaccurate, are misunderstood and relied upon way too heavily.
  10. QNH is part of an aeronautical code covering QAA - QNZ. Similar Q codes are used in military and nautical functions. Here’s a link for your reference.
  11. I’m keen to see the airspace model. I reckon Camden will see a 2000’ Class C step overhead. I base this on the steps around KSA. Bankstown will be severely affected and kill any practical abinitio flight training.
  12. A requirement for RAAus ops, but not GFA or Hot Air Balloon pilots in Class C or D.
  13. Yes, very limited indeed. Exemptions are issued to individual schools and audited on a regular basis. The exemptions require renewal along with the going fee, quite different to the GFA and Balloon Federation certificate holders. Probably logical when RAA (AUF) airplanes resembled flying clotheslines, cruised at 25 knots and were fitted with Victa Lawnmower engines.
  14. The RAA schools operating at Class C or D hold exemptions allowing students to solo. Once the pilot has gained their RPC they can no longer operate in CTA, more CASA logic in place.
  15. It sure does, but you must keep your Part 61 PPL medical and AFR current to exercise the privileges on an RAA RPC in controlled airspace. CASA argue you need the medical and AFR to be safe to operate in controlled airspace. However, glider and balloon pilots can operate in controlled airspace without any CASA issued medical or Part 61 quals. Camden is a classic example of glider ops in controlled airspace without the need to hold a PPL or medical (aside from a self certified one), these ops include motor gliders. A pilot holding only RAA quals can happily operate from Camden when the tower is closed, but not when it’s active. That implies it’s safer to operate when the tower is shut?
  16. That’s easily fixed, stop auditing.
  17. The GFA have pilots flying quite sophisticated motorised gliders, these aircraft are flown into controlled airspace by pilots holding self certified medicals. The precedent has been set, RAAus should have used the GFA example for both increased MTOW and CTA access. The Grob 109 and Super Xiamango have an MTOW of 850kg.
  18. A few things to remember about radials and hydraulic locks… - never force the prop through a hydraulic lock when pulling through. Big radials have a clutch on the starter that’ll slip rather than force rotation through a lock. Big radials turn the engine over with mags off for a set number of blades (revolutions) - if you force an engine to turn over through a hyd lock you’ll bend or break a link rod. A bent one will likely fail at a later time. - do not pull the engine backwards. This can force the oil into the intake manifold and suck it back in during engine start and break / bend a rod.
  19. Dealing with the CASA frontline staff was never an issue. It’s the day to day business side of things and the idiotic “regulation reform” (ie bureaucratic BS) that makes running a school not worth the effort. The customers are usually the reason you keep at it and being a line instructor would be ok.
  20. Having started, run and sold a successful flying school I can assure you it’s not as profitable as the hourly rate x hours might appear. The various overheads associated with any small business are there, once you factor in financing airplanes and maintenance costs to keep the machines in a serviceable / presentable state it’s a tough game. I’ve been approached a few times since selling the school to set up new ventures. Once you run the numbers it’s not worth the effort, it would simply be an expensive hobby.
  21. I’d rather mix with birds than people flying with the autopilot engaged and head buried in their EFBs. As for engine failures, I have my plan sorted and the airplane I fly either runs or doesn’t so I don’t have tank changes, pumps etc.
  22. I fly everywhere at 500’ AGL, too high for Ag aircraft and Drones, too low for the EFB crowd. I avoid populous areas and airfields, I’ll climb to circuit entry height approaching my destination.
  23. DCA recorded an accident at Highfield on 27/12/1968 involving a 180HP Arrow (PA28R-180), the aircraft was destroyed. Maybe this is the event?
