Marty_d Posted February 15, 2017 Share Posted February 15, 2017 Hey all, Starting work on the lower rear fuselage of the 701 and realise I need nutplates for the rear access hatch (and other inspection panels in wings). Don't really want to do an order to the US because the freight would be far more than the item cost. Is there anywhere in Aus that sells these? I'd need about 50 of the plates and screws. Part numbers are: Plates: MS107SL3 Screws: AN525-10R7 Also #40 blind rivets, not sure if these have to be anything special as the nut and plate would be taking all the load. Thanks! Cheers, Marty Link to comment Share on other sites More sharing options...
rick morawski Posted February 15, 2017 Share Posted February 15, 2017 Hey all,Starting work on the lower rear fuselage of the 701 and realise I need nutplates for the rear access hatch (and other inspection panels in wings). Don't really want to do an order to the US because the freight would be far more than the item cost. Is there anywhere in Aus that sells these? I'd need about 50 of the plates and screws. Part numbers are: Plates: MS107SL3 Screws: AN525-10R7 Also #40 blind rivets, not sure if these have to be anything special as the nut and plate would be taking all the load. Thanks! Cheers, Marty Hi Marty, I have used ASAP Aircraft spares in Caboolture, Qld a few times, they will email you a quote beforehand so you don't crap yourself later, and very quick with the mailing too. Check their website or call them. Cheers Rick Link to comment Share on other sites More sharing options...
AllanBendigo Posted February 15, 2017 Share Posted February 15, 2017 Hey all,Starting work on the lower rear fuselage of the 701 and realise I need nutplates for the rear access hatch (and other inspection panels in wings). Don't really want to do an order to the US because the freight would be far more than the item cost. Is there anywhere in Aus that sells these? I'd need about 50 of the plates and screws. Part numbers are: Plates: MS107SL3 Screws: AN525-10R7 Also #40 blind rivets, not sure if these have to be anything special as the nut and plate would be taking all the load. Thanks! Cheers, Marty Hi Marty You can try Superior aircraft parts in Brisbane they have a big supply of hardware or Aircraft Propellers and Spares. ... Building 127, Third St MoorabbinAirport. They have lots of hardware too Cheers 1 Link to comment Share on other sites More sharing options...
Marty_d Posted February 15, 2017 Author Share Posted February 15, 2017 Thanks Allan! How's that Cruzer coming along? 1 Link to comment Share on other sites More sharing options...
Marty_d Posted February 15, 2017 Author Share Posted February 15, 2017 Hi Marty,I have used ASAP Aircraft spares in Caboolture, Qld a few times, they will email you a quote beforehand so you don't crap yourself later, and very quick with the mailing too. Check their website or call them. Cheers Rick Thanks Rick! Link to comment Share on other sites More sharing options...
old man emu Posted February 15, 2017 Share Posted February 15, 2017 I think that you have mis-quoted the nutplate part number. I think it should be MS21075L3. Give Dave Dent at QED Aircraft Parts and Hardware (02 464551514) a call. Do you have a part identifier for the blind rivet? Dave should have those also - as well as the screws. 1 Link to comment Share on other sites More sharing options...
Marty_d Posted February 16, 2017 Author Share Posted February 16, 2017 Thanks OME. You are correct, I stuffed up the reference, it is indeed MS21075L3. I took it off the photo building guide instead of the plans and it was wrong there. Just gave Dave Dent a ring and he's getting back to me with a quote. Link to comment Share on other sites More sharing options...
M61A1 Posted February 16, 2017 Share Posted February 16, 2017 http://www.cherryaerospace.com/docs/catalogs/CA-1036.pdf Link to comment Share on other sites More sharing options...
Marty_d Posted February 16, 2017 Author Share Posted February 16, 2017 Thanks M61! Link to comment Share on other sites More sharing options...
bexrbetter Posted February 16, 2017 Share Posted February 16, 2017 Would this do? 2 Link to comment Share on other sites More sharing options...
Yenn Posted February 16, 2017 Share Posted February 16, 2017 Rather than use drawn rivets to hold the nutplates, a countersunk solid rivet would give a closer fit. 1 Link to comment Share on other sites More sharing options...
facthunter Posted February 16, 2017 Share Posted February 16, 2017 There's no real load on the rivets. Soft aluminium countersunk plain rivets would do. I think I got the last ones I used from Aviall at Airport West, near Essendon Airport. (not the rivets, the nutplate(s) Nev. 1 Link to comment Share on other sites More sharing options...
AllanBendigo Posted February 16, 2017 Share Posted February 16, 2017 Thanks Allan! How's that Cruzer coming along? It's coming along fine Going down GA experimental and fixing a 0-320 140 hp engine Heavy I know but heaps of power 2 Link to comment Share on other sites More sharing options...
fly_tornado Posted February 16, 2017 Share Posted February 16, 2017 try these out and let us know if they are any good Click Bond, Inc. Link to comment Share on other sites More sharing options...
Marty_d Posted February 16, 2017 Author Share Posted February 16, 2017 Thanks everyone, I put in an order with Superior Aircraft Parts. Their cost for the nutplates was $22 for a bag of 25, compared with another place that quoted $2.09 each. Unfortunately Dave Dent didn't call back yet so I went with Superior. Link to comment Share on other sites More sharing options...
Marty_d Posted February 16, 2017 Author Share Posted February 16, 2017 It's coming along fineGoing down GA experimental and fixing a 0-320 140 hp engine Heavy I know but heaps of power She'll be a beauty, can't wait to get back to Bendigo and see her. 1 Link to comment Share on other sites More sharing options...
M61A1 Posted February 16, 2017 Share Posted February 16, 2017 try these out and let us know if they are any good Click Bond, Inc. Clickbond are good for standoffs bonded to composite parts, but I hate their anchor nuts (nutplates), as it just takes a little bit of hamfist (and it might not be you undoing it) to push it off the other side when undoing a screw, and especially it it's a bit tight with the self locking medium. Way less effort to drill two holes and pull two rivets. Link to comment Share on other sites More sharing options...
fly_tornado Posted February 17, 2017 Share Posted February 17, 2017 good points Link to comment Share on other sites More sharing options...
M61A1 Posted February 17, 2017 Share Posted February 17, 2017 Would this do? That's not a nut plate....this is a nutplate... Link to comment Share on other sites More sharing options...
facthunter Posted February 17, 2017 Share Posted February 17, 2017 Bet that hurt. Nev Link to comment Share on other sites More sharing options...
SDQDI Posted February 17, 2017 Share Posted February 17, 2017 I have heard of people giving their right arm for a good photo but that is taking it too far! Link to comment Share on other sites More sharing options...
Blueadventures Posted February 17, 2017 Share Posted February 17, 2017 I have heard of people giving their right arm for a good photo but that is taking it too far! Maybe lost a bet? :) Link to comment Share on other sites More sharing options...
Admin Posted February 17, 2017 Share Posted February 17, 2017 That's not a nut plate....this is a nutplate...[ATTACH=full]48551[/ATTACH] Crikey I had just taken a mouthful of breakfast when I saw that post...no more breakfast for me 3 Link to comment Share on other sites More sharing options...
bexrbetter Posted February 18, 2017 Share Posted February 18, 2017 Crikey I had just taken a mouthful of breakfast when I saw that post...no more breakfast for me They have been served up on a plate for me here on more than one occasion ... (pigs). Link to comment Share on other sites More sharing options...
Yenn Posted February 18, 2017 Share Posted February 18, 2017 It is not always that the Matador wins, sometimes the bull has a good day. 1 1 Link to comment Share on other sites More sharing options...
