hihosland
Everything posted by hihosland
  1. Hi Ian Loads and looks fine. My old eyes, however, would appreciate a more bold and blacker font for the body text of the site. and the "Forums" button on the Off Topic page works OK but not on the Rec Fly page. cheers and thanks for all the grand effort.
  2. the tanks have all about faced and gone to Hong Kong where they have proved to be absolutely useless because al the umbrellas have...
  3. it is now all starting to rust away. But no matter you soon will not be needing these bases because ...
  4. then in her distress she had a flash of nostalgia and remembered her dear uncle, he of the bobbing monocle, declaring WD40 would fix anything including misbehaving zippers, then having cured the zipper conundrum with WD40 still in hand she remembered there was something horribly wrong with Rocky and with a flash of inspiration she ...
  5. to the haunting hypnotic beat of the star-bellied-sneetches and their ..
  6. a delegation from the IOC with an announcement that our man Boris was to represent the nation at the bad hair Olympics. duly came the final with three remaining contestants Boris, Donald and Kim fighting for the podium with all three pushing and shoving and trying to balance on the top spot. The IOC calls in a whole alphabet of international consultant firms who recommend a circular podium with only one flat surface. All three then refuse to stand on such an abomination of the competitive spirit and head off to their respective TV interviews meanwhile Xi with three medals around his neck and the podium under his arm is seen
  7. the British PM wondering .
  8. Is it possible to safely use 18mm coolant hose where Rotax calls for the difficult to source 17mm? many thanks
  9. The FAA allows ferry or re positioning flights without passengers.
  10. If I need to use my right hand for anything including flaps then left hand on the stick works well. If correctly trimmed there should be no need to touch the stick for the interval needed to adjust the flaps certainly attitude changes with flap setting changes but not violently nor dramatically enough that no hand on the stick creates any potential hazard. Skyranger is a very benign aircraft to fly and any in likely atmospheric upset a trimmed Skyranger will return to its original condition without any control imputs
  11. The alignment of the WWII airfield is still visible due south of the township of Bayles
  12. Flying by wire?
  13. took me a while
  14. True Skippy, But my concern is/was that every time that this system is used at some point the fuel/air mixture would be at a potentially explosive ratio. Whereas with other systems the gas mixture in both the receiving and the delivering containers would be too rich at all times. cheers
  15. I used a foot operated lilo pump to pressurise a jerry can and it worked exceedingly well. That is until I thought about it a bit more Thoughts being 1 liquid fuel is not explosive 2 fuel-vapour is not explosive 3 fuel-vapour/air mixture is explosive 4 pressurised fuel-vapour/air mixture is a potential flame thrower. With those thoughts in mind I went back to decanting liquid fuel from jerry can into Mr Funnel into aircraft.
  16. Wing and a prayer six o'clock high
  17. Fred did say " They have already proposed a seperate yearly medical at 75 which was only removed from the proposed ops manual after it was pointed out that a yearly medical is already required for a driver’s licence. I say watch closely. " Being 75+ When I renewed my membership online last week, I was forced to upload a Dr's certificate before I could proceed further with the renewal process
  18. life's little stresses
  19. PS http://nzcivair.blogspot.com.au/2008/12/from-shoe-box-1.html
  20. from a NZ data base CA28-9 ZK-BZO WFU after F/L from fuel exhaustion near Pahiatua Track, Tararua Ranges, 17Jan72. Stored Wellington; to M Nicolls at Ohakea for rebuild as Wirraway. to Australia for Paul Wheeler, Qld
  21. Silverstream, Upper Hutt (04) 563 7348 Silver Stream Railway | Railway Heritage Museum and Steam Train Rides, Upper Hutt, Wellington, NZ
  22. Plane crashes at Warbirds opening apologies for wrong thread, I can't see how to delete post or move
  23. the box my Skyranger came in?
