johnm
Everything posted by johnm
  1. rocks or roses .................. maj would be enjoying this farewell maj
  2. thanks for the new word Debbie - androgynous - had to look that one up ............... reading between the lines it looks like your welcome and trust it stays that way
  3. birdy looks quiet healthy ....... must be only a bleeding nose
  4. yes Poteroo .............................. tell us a few tales please - don't keep them all to yourself
  5. we were so poor that the power utility was never paid so we just resigned ourselves to watching television in the dark
  6. only if the town planner catches you - even then they might not know the difference (I doubt the land owners would care)
  7. there would n't be a fracas if aviatrix's described aviators aircraft enclosures as a cockpit any reputable pet shop would probably also sell a pussy enclosure (probably different descriptive words) its just the political correctness thingy (BUT $25k !)
  8. interesting point - an air cooled engine with a power on approach - a steeper approach is more difficult to achieve with a water cooled motor all you do is go to idle power is this correct logic ?
  9. 'ere's one where when reserve was included - unusable fuel was not considered - assuming link will work: http://www.caa.govt.nz/Script/Accident_Details.asp?Oc=14/2869
  10. the announcement will be that the announcement will be made the following Monday
  11. I learnt in the tomahawk and my instructors and I did many spins - they actively taught them in 1983 ? ............... They even told me to go up solo and do spins which was done after I got my ppl I used to take thrillseekers up to do spins (in hindsight probably not a good idea) I think then the NZ authority directed no more spins in the tomohawk so that stopped - a pilot thereafter died when his tomohawk went into the sea from circuit height - cause not known I'd gladly do some spins again - with an instructor though first off
  12. great for the loose leaves and grass .......... if you are into that sort of thing
  13. ............... at least we don't have membership numbers (yet) for the local, state and federal elections comrades !
  14. Take the strobe / light thingy off the wing tip and have a giz in there ............ assuming there is no vent disconnect - just pushed in There should be say 10 mm of black plastic vent tube protruding out rear of wing tip fairing - sounds like vent tube has been pushed in ?
  15. Take the strobe / light thingy off the wing tip and have a giz in there ............ assuming there is no vent disconnect - just pushed in There should be say 10 mm of black plastic vent tube protruding out rear of wing tip fairing - sounds like vent tube has been pushed in ?
  16. heres one !: .................... http://www.recreationalflying.com/threads/sb-582-drifter-for-sale.133666/
  17. heres one !: .................... http://www.recreationalflying.com/threads/sb-582-drifter-for-sale.133666/
  18. ......................... be good for open cockpit like a drifter
  19. ......................... be good for open cockpit like a drifter
  20. .............. be intriguing to know if the Ballarat Tecnam was a serial number 001 to 013 per post #4 .............. Ground station to Ballarat ............ do you read me ?
  21. tecnam - ballarat 31.3.15 .............. this was in the RAA 2015 incident list - can I ask ? - does anyone know what caused this event (twice) ........ fault identified ? quote: ' Completing a check flight after inspection. Aircraft was on downwind RWY18 85 kts, straight and level. The aircraft rolled and yawed to the right without warning. PIC applied full left rudder and full power and the aircraft shuddered and recovered. Recovery was not instant but did return to level flight. Rudder required a lot of pressure to move much more than normal. Lost about 200 feet. Completed circuit and made a full stop landing without further incident. The Aircraft had suffered a similar incident on Sunday 29/3/2015. . Aircraft Grounded until fault identified and repaired.'
  22. ......... rumor has it the conspirators will be shortly stealing the flaperon bit back to have again....................... an airworthy plane
  23. yes droll - I know of a commercial pilot in airlines who was seriously considering stopping flying ............... to avoid the tedious red tape and procedural stuff - just a nice 8 to 5 job .......... nothing else to do outside those hours as to the cause of crashes - well its because .............................
