Garfly
Everything posted by Garfly
  1. The last time I saw Franco was last May at Deeral.
  2. Whilst on the tricky topic of best-glide, I've found some of this discussion useful: Also, this vid is good at demonstrating that minimum sink is not the same as maximum range (wind effects aside): https://www.youtube.com/watch?v=ZP8KL4j9yA8 Also, I've been playing around with OzRwy's Glide Assistant in a simulator. It can can be used in planning and/or in real time. Not sure if, faced with an engine out situation you'd think to consult it but a quick glance might suggest a direction for longest range - in prevailing winds aloft. Anyway, it automatically cuts out at 1500' AGL probably in order to suggest that now is definitely look-outside time. User guidance here (18.5) : 18. Special Features DOCS.OZRUNWAYS.COM And this academic take is exhaustive (and exhausting) and might interest those who know the maths. Straight Gliding Flight | Academic Flight ACADEMICFLIGHT.COM This article deals with straight gliding flight, as it is encountered during an engine-out emergency or in a glider. Controlling (and maximizing) glide
  3. Speaking of wooden propellers - a tall tale, and true, of the Canadian north.
  4. It's sad to see young Ido Segev again, as large as life, in this wonderful Mike Rudd video. (He was one of the four pilots lost in the Mangalore mid-air tragedy.) https://www.theage.com.au/national/victoria/fly-ido-young-pilot-remembered-after-two-planes-crash-killing-four-20200220-p542ld.html
  5. But back then, we'd never have known each other, right? (And for all that, I reckon it's more for better than for worse ;- )
  6. BTW P-P, Chris Weber, the builder of Valkyrie 1684, has said that he feels no special proprietary rights over the name for that one-off of his, so there'd be no need to change it on his account, at least. If you want to confirm that with him, let me know.
  7. (Then there's the Philomena Cunk school of aviation journalism ;- )
  8. Ch7 News: https://www.youtube.com/watch?v=CI2G7Yo8GZM
  9. Absolutely, they seem to worry him a lot ... even airframe parachutes worry him - a substitute for good piloting. That must please his GA Cirrus colleagues a lot. I guess their training is never going to save their lives. Equally opinionated folks worry about other things, like the dangers of a GA fleet full of 40 or 50 year old machines. And just look at that shiny RAAus, Bristell leading the story ... but a few years young. What a messed up piece of crap-journalism. Training saved pilot's life Pilot Keith Link from Cohuna in regional Victoria survived a plane crash after the engine of his commercially built Cessna failed mid-flight near Bendigo in 2020. He said his pilot training helped save his life but that more improvements in the sector were needed. Pilot Keith Link survived a light plane crash in 2020. (ABC News: Tyrone Dalton) Mr Link said he wanted licensed aircraft maintenance engineers to sign off on all aircraft after every 100 hours of flight or every 12 months. "When I see a plane with a parachute attached to it, I sort of think that's a substitute for being a good pilot," he said.
  10. True, but whenever I've done (dual) engine-off practice glides the Rotax has burst back to life instantly. But still, nobody depends on it so that training is always done within easy reach of an ample runway.
  11. Sorry no substance.
  12. The scene depicted in the Italian video (above) would be legal here. In pursuit of greater competence and safety, I would gladly seek out such training just as I would seek out, say, upset recovery training.
  13. I have also done that kind of testing with a CFI (and we reached the same conclusion) and it is legal under RAAus rules.
  14. Unintended touchdown WWW.FLIGHTSAFETYAUSTRALIA.COM As it was a nice day, I thought it would be good to take the plane out for a trip around the local area and was wondering about performing an engine-off landing as I had practised doing them now and again quite...
  15. Aren't those the figures you reported in the original post of this thread (4 years ago)? "For the Savannah, 50kts is the speed for best glide ratio, as determined by earlier testing. Times recorded for these tests are - at idle 101 seconds, at prop stopped 94 seconds. At idle - 101sec/1000ft = 594fpm descent rate = 8.5:1 glide ratio @ 50kts. Prop stopped - 94sec/1000ft = 634fpm descent rate = 7.9:1 glide ratio @ 50kts. So for each 1000 feet of descent, the aircraft will glide 8,500ft at idle or 7,900ft with prop stopped. So that’s 600ft (182m) less distance at prop stopped than at idle."
  16. While looking for that anti-heat-soak cowl-flap story for re-posting in Skippy's Linear Actuator thread I was taken back to the main topic of JG3's original thread: Prop Stopped. I reckon it's probably worth a bump; some interesting discussion around whether we should, from time to time, practise real dead-stick landings. And then, out of the blue, I came upon this example. (I see the instructor returned the switches to ON ready for a restart if needed) :
  17. This'd be the post you're referring to, Marty. As you say (and AFAIK) the device is only meant to reduce heat soak under the cowl on the ground.
  18. Agreed, and in the second video story I thought he did well to descend underneath the converging Cessna because even though he too was in a high wing he probably had a better chance of keeping sight of the threat looking forward and upwards until it passed over (as opposed to climbing and losing it under the nose.) In the first story he says they were both vertically constrained by a cloud layer just above circuit overfly height. In that case, he reckoned his take-away was he should have been less fixated on his original joining plan when faced with unexpected same level traffic.
  19. This fairly recent video by a young YLED (Lethbridge) pilot tells two stories from which, he says, he took lessons about traffic conflicts near airports. The first shows how the other plane's OzRwys traffic helped with separation when his own radio comms were, he thought, somewhat lacking. And the second (04:00), shows how it was the other plane's landing lights that saved the day when that pilot's radio call had placed him somewhere else entirely. I guess we all agree, see-and-avoid needs all the help it can get. Anyway, kudos to FlightFix for sharing what he's learned in such engaging, well produced videos.
  20. It seems this is the fuel consumption range Turbotech claims: 109hp/140hp/160hp 19l/h / 20l/h / 21l/h eco cruise 24l/h / 32l/h / 35l/h 75% power
  21. I'm pretty sure I have been awake. Unless ... Anyway, I'm not the only one: "The FAA has a voluntary pilot safety program, Operation Lights OnPilots ... pilots are further encouraged to turn on their landing lights when operating below 10,000 feet, day or night, especially when operating within 10 miles of any airport, or in conditions of reduced visibility and in areas where flocks of birds may be expected, i.e., coastal areas, lake areas, around refuse dumps, etc." airplaneacademy.com | AIRPLANEACADEMY.COM
  22. Theatrics aside, Skippy, landing lights on final are very often visible before the airframe that they're stuck to. This is a big help for anyone about to enter who might have missed the call. Not to mention, for tower controllers everywhere.
  23. I think the guy in the video is, temperamentally, a bit beyond the usual trainee pilot profile. Still, his extreme example can still be a lesson to us all. Anyway, their survival probably says something for the Tecnam P92's crash cage.
  24. Yes, although they say it can also run on many types of fuel. (Presumably not mixed at will, though.) And I think there are parts of the world where Avgas is much harder to find than Jet A1 is. But hey, those are first world problems we won't have to face. ;- )
  25. Yeah, one Gogetair dealer in Europe (A4 Aviation) claim to be looking at a cruise efficiency for the G750TP between 15 and 18 LPH - of cheaper Jet A1. (see YT vid below at 01:30) And with a 3,000 hr TBO they hope to whittle down the ICE price advantage over the service life. Although some argue that in typical GA use a turbine could run out of cycles well before TBO hours. Others reckon that in its 2+2 Mosaic config it could give Cirrus a run for its money in the US market. In any case, it seems Gogetair don't envisage their G750TP operating above 20,000' https://www.youtube.com/watch?v=7My16WEnaPY "... the G750TP combines the advantages of a gas turbine engine – smooth, vibration-free flight, and reliability – with impressively low fuel consumption and a long 3,000-hour TBO." A4Aviation News - A4 Aviation WWW.A4AVIATION.COM Latest news articles and updates from A4Aviation
