Garfly Posted October 29, 2018 Share Posted October 29, 2018 Dying pilot tries to clear his name after fatal plane crash This relates to the earlier thread: https://www.aircraftpilots.com/threads/cessna-down-with-4-on-board.156745/ Link to comment Share on other sites More sharing options...
Teckair Posted October 29, 2018 Share Posted October 29, 2018 I will make sure I see that tonight how this person thinks he can clear their names is hard to imagine after the cowboy outfit they ran. 2 Link to comment Share on other sites More sharing options...
alf jessup Posted October 29, 2018 Share Posted October 29, 2018 I will make sure I see that tonight how this person thinks he can clear their names is hard to imagine after the cowboy outfit they ran. I’m with you Teckair, No a very professional run outfit after seeing the videos before they were pulled. Cameras don’t lie and it is all good and well to act like cowboys but when you mess up or have an incident it all comes back to bite you on the arxe. Not one bit of sympathy from me, best thing was CASA pulling the AOC and the licences IMO Link to comment Share on other sites More sharing options...
Thruster88 Posted October 29, 2018 Share Posted October 29, 2018 A non cowboy pilot would do the downwind at more than 80 agl just because you never know when the engine might fail. Beach inspection excuse is b.s. 1 Link to comment Share on other sites More sharing options...
giantkingsquid Posted October 29, 2018 Share Posted October 29, 2018 Yoke was a loooonngg way back in that turn. Stall warning whistling away I think. An unfortunate situation for all involved. Link to comment Share on other sites More sharing options...
Teckair Posted October 29, 2018 Share Posted October 29, 2018 Watched the video taken from inside the plane. Here is my thoughts a 180 degree turn from that height with out power was not achievable. I had thought the turn must have been attempted because there was no other option but the video appears to show that is not the case. The plane was flying low over the water and not in the best position to be checking the beach sand surface. The plane was being flown in a manner as though an engine failure was not possible. He was trying to defend the indefensible. 2 Link to comment Share on other sites More sharing options...
alf jessup Posted October 30, 2018 Share Posted October 30, 2018 Weren’t most trained to do precautionary S&L in to the wind at about 70kts with a stage of flap at about 150 ft not punting along at cruises speed 80 ft above the water? Link to comment Share on other sites More sharing options...
fly_tornado Posted October 30, 2018 Share Posted October 30, 2018 from watching the footage I thought if they had tried to do a 90 degree turn and run up the beach into the dunes it would have been a lot less severe landing. Link to comment Share on other sites More sharing options...
APenNameAndThatA Posted October 30, 2018 Share Posted October 30, 2018 Well, I'm no expert, and I only saw the video once, but it looked like when the engine stopped, the nose came *up*, then the stall warning came on. Flying with the stall warning on will *shorten* the glide path. The video does not help clear anyone's name. Link to comment Share on other sites More sharing options...
Thruster88 Posted October 30, 2018 Share Posted October 30, 2018 It is normal to zoom up in a plane that has inertia (Not a thruster !) to best glide speed. The engine failed at 80 agl and climbed to 150 before starting the 180 turn. If the aircraft had been at 200 agl when the engine failed the pilot would have made it. https://www.atsb.gov.au/publications/investigation_reports/2017/aair/ao-2017-005/ Link to comment Share on other sites More sharing options...
Teckair Posted October 30, 2018 Share Posted October 30, 2018 It is normal to zoom up in a plane that has inertia (Not a thruster !) to best glide speed. The engine failed at 80 agl and climbed to 150 before starting the 180 turn. If the aircraft had been at 200 agl when the engine failed the pilot would have made it.https://www.atsb.gov.au/publications/investigation_reports/2017/aair/ao-2017-005/ Maybe but I wouldn't try it I would have gone straight ahead and slightly to the left to the waters edge. Might wreck the plane but less impact. 1 Link to comment Share on other sites More sharing options...
Yenn Posted October 30, 2018 Share Posted October 30, 2018 The pilot is going to have an uphill battle, given the record of the operator. I have looked at where he was heading to land and declined it. They used to land on aeroplane beach, where there is ample room, but that site didn't look good to me, although a friend landed there in his Savannah. Link to comment Share on other sites More sharing options...
Teckair Posted October 30, 2018 Share Posted October 30, 2018 The pilot is going to have an uphill battle, given the record of the operator. I have looked at where he was heading to land and declined it. They used to land on aeroplane beach, where there is ample room, but that site didn't look good to me, although a friend landed there in his Savannah. A Savannah is stol but it could not make the turn this guy tried to do. Link to comment Share on other sites More sharing options...
Guest jairob Posted November 3, 2018 Share Posted November 3, 2018 Hello everybody i am a new student to get my PPL in a cirrus I have 35 hours only and to my, I find a little difficult the radio calls so if somebody has a suggestion how I can memorized the phraseology ?? thanks Link to comment Share on other sites More sharing options...
Downunder Posted November 3, 2018 Share Posted November 3, 2018 Get a scanner and listen in. Listen to others while you are relaxed and on the ground. Link to comment Share on other sites More sharing options...
shafs64 Posted November 3, 2018 Share Posted November 3, 2018 Four adults in a 172 is a big load it would of been at the high end of its limits. I saw the story and video and that turn was very steep and low. we all know how that story ends. Link to comment Share on other sites More sharing options...
Yenn Posted November 4, 2018 Share Posted November 4, 2018 Now I understand why he has been such a cowboy for so long, brain tumour. 1 Link to comment Share on other sites More sharing options...
turboplanner Posted November 4, 2018 Share Posted November 4, 2018 Hello everybodyi am a new student to get my PPL in a cirrus I have 35 hours only and to my, I find a little difficult the radio calls so if somebody has a suggestion how I can memorised the phraseology ?? thanks Easy; Set up a spreadsheet with: Column 1: the listen or transmit locations starting with pre-start up on Line 1 then down location by location Column 2: One line down from"Pre-start" type the phrase or action, which in this case might be "Set frequency, listen out" And so on down the page of locations looking like this: Pre Start Set frequency, listen out Taxy etc. (On sheet 1 you might limit this to the circuit only - you can do the departure-cross country-join later) Insert enough blank lines (about 30 to start with) until all you can see is "Pre Start" Say out loud or write down the phrase without peeking Click on the down scroll button and see if you have it world-correct; if not don't worry, visualise what you would be doing at that point, relate the transmission to it, and have another go when you redo the sequence again. It's important you visualise the phrase so it makes sense to you and relates to your position and action rather than trying to parrot it off. The two most important words in all the above are "without peeking". I've lost count of the number of times I've tried to learn off a list of phrases, where I could see everything on the page then got into an aircraft and my mind's gone blank. Link to comment Share on other sites More sharing options...
KRviator Posted November 4, 2018 Share Posted November 4, 2018 The worst part about this whole sorry saga: They're probably not alone in their antics... 1 Link to comment Share on other sites More sharing options...
