FlyingVizsla Posted Thursday at 03:56 AM Posted Thursday at 03:56 AM https://www.abc.net.au/news/2025-08-21/robbie-katter-crashes-plane-for-second-time-at-mount-isa-airport/105676612  Robbie Katter MP Mooney landing gear issue - Mount Isa airport Mr Katter said the crash was caused by pilot error, related to the landing gear of the plane, during a three-day trip through his electorate in the Gulf of Carpentaria. He had taken off from Normanton, 500 kilometres north of Mount Isa, earlier that day.   1
Blueadventures Posted Thursday at 04:21 AM Posted Thursday at 04:21 AM 1 minute ago, Thruster88 said: He might have to get a Cirrus. Dad may have to explain the merits of a fixed undercarriage to him, insurance may also. 2nd I think may be wrong. 1 1
facthunter Posted Thursday at 05:16 AM Posted Thursday at 05:16 AM Quite a few CASA people have Landed gear up. Most Pilot's have NEVER done it. It's too Noisy, and you can't taxi.  Nev 1 2
onetrack Posted Thursday at 06:47 AM Posted Thursday at 06:47 AM (edited) This was his first effort, May 14th, 2023. Seems like he might be a bit of a slow learner, I thought doing it once would be enough of a wake-up call.  Perhaps he needs a better wife - one who reminds him when he's going to do something wrong. 😄  Qld MP Robbie Katter 'embarrassed' but unhurt in landing gear mishap at Mount Isa Airport - ABC News WWW.ABC.NET.AU The North Queensland MP says "it's just the ego that hurts" after he forgot to put down the landing gear before hitting the runway on Sunday.  Edited Thursday at 06:49 AM by onetrack
rgmwa Posted Thursday at 06:52 AM Posted Thursday at 06:52 AM 3 minutes ago, onetrack said: Perhaps he needs a better wife - one who reminds him when he's going to do something wrong. 😄  A checklist would be a lot cheaper. 1 2
Blueadventures Posted Thursday at 07:24 AM Posted Thursday at 07:24 AM 33 minutes ago, onetrack said: This was his first effort, May 14th, 2023. Seems like he might be a bit of a slow learner, I thought doing it once would be enough of a wake-up call.  Perhaps he needs a better wife - one who reminds him when he's going to do something wrong. 😄  Qld MP Robbie Katter 'embarrassed' but unhurt in landing gear mishap at Mount Isa Airport - ABC News WWW.ABC.NET.AU The North Queensland MP says "it's just the ego that hurts" after he forgot to put down the landing gear before hitting the runway on Sunday.  Seems he had the gear down and landed ok, then during taxi inadvertently retracted. He's a good bloke so will have to get used to copping comments from his mates. 1
BurnieM Posted Thursday at 08:28 AM Posted Thursday at 08:28 AM (edited) I do not know the panel layout of this particular plane but it surprises me the number of critical switches on all type of planes that are not guarded. Â Edited Thursday at 08:30 AM by BurnieM 1
Arron25 Posted Thursday at 09:02 AM Posted Thursday at 09:02 AM 1 hour ago, Blueadventures said: Seems he had the gear down and landed ok, then during taxi inadvertently retracted. He's a good bloke so will have to get used to copping comments from his mates. Had a Bonanza do this here a few years ago ( a high multiple 1000hr pilot) something to do with the Flap/Gear levers.. and ..no.. no lockout??? 1
Litespeed Posted Thursday at 10:29 AM Posted Thursday at 10:29 AM From memory a Mooney M20 has a big lever that operates the retracts. It very obvious in its position and I would think hard to forget. Â Retracting after landing seems rather odd. 1 1
onetrack Posted Thursday at 12:37 PM Posted Thursday at 12:37 PM The early M20's up to 1965 had manually retractable undercarriage with a big "Johnson bar" lever. "Johnson bar" comes from locomotive terminology, and is a term used on a wide range of equipment, where you need to pull a big lever. Â From 1965, Mooney offered electrically activated undercarriage retraction on the M20 as an option. In 1969, the manual retraction system was dropped completely and only electric retraction was offered from then on. Â VH-TWV was built in 1985 according to the rego details, so it will have electrically-operated undercarriage. Â If the undercarriage was retracted while taxying, then that's an aircraft fault, because the M20 with electric retraction has an airspeed lockout to prevent retraction on the ground. 1
Marty_d Posted Thursday at 10:36 PM Posted Thursday at 10:36 PM Wouldn't any retractable system also have a mechanical lock so any load on the gear would prevent retraction? 2
skippydiesel Posted Friday at 12:06 AM Posted Friday at 12:06 AM I thought the anti retract was a something called an "anti squat switch" - simply a switch, activated by the weight of the aircraft on the suspension, that opened the electrical circuit.😈 1
facthunter Posted Friday at 12:23 AM Posted Friday at 12:23 AM Most gear lock down is by the "OVERCENTRE' mechanism which often uses a spring as well for the Alternate extension Free fall case.. Green means Down and locked. when you select UP the first action is to unlock the strut to allow it to fold. I know weight on it makes it harder to retract and sometimes there's a restrictor Pin in the Gear Lever like a trigger on a rifle to prevent inadvertent retraction. BEECH but the flap and gear switches next to each other?????  Robbie needs to be MORE careful what HE touches when he's in a PLANE. Nev 1
Thruster88 Posted Friday at 03:33 AM Posted Friday at 03:33 AM 4 hours ago, Marty_d said: Wouldn't any retractable system also have a mechanical lock so any load on the gear would prevent retraction? There are many types of retract mechanisms and safetysystems, none are fool proof. The main benefit of RG in low horse power aircraft is to provide work for LAMEs. 2 3
PureCaboose Posted Friday at 03:40 AM Posted Friday at 03:40 AM I know of a 182RG that retracted the gear then the instructor sayd 'retract flaps' and someone grabbed the wrong lever. Good thing it was a grass strip...... 2
facthunter Posted Friday at 06:07 AM Posted Friday at 06:07 AM HI-wing Cessna RG's have a lot of drag during the retract stage. It's part of Knowing THAT Plane. Normally "Gear up" is the FIRST thing you do (unless it's a very long runway). Nev 1
Geoff_H Posted Friday at 06:46 AM Posted Friday at 06:46 AM On 21/08/2025 at 2:17 PM, Thruster88 said: He might have to get a Cirrus. Never! 2
Geoff_H Posted Friday at 06:49 AM Posted Friday at 06:49 AM 6 hours ago, skippydiesel said: I thought the anti retract was a something called an "anti squat switch" - simply a switch, activated by the weight of the aircraft on the suspension, that opened the electrical circuit.😈 Mooneys have an airspeed switch. An air pressure switch in the pitot line. I.had to buy one at +$2k. 1
facthunter Posted 23 hours ago Posted 23 hours ago (edited) When Large Planes are left Parked, PINS are placed in the Undercarriage and the wheels are chocked.  Nev Edited 23 hours ago by facthunter 1
