turboplanner Posted May 10, 2020 Share Posted May 10, 2020 Roads, railway lines, rivers, hills and anything man made will be useful to try and locate where you are in relation to the map. I would not like to be in this situation. Which is a good reason to have a practice every few flights. Link to comment Share on other sites More sharing options...
onetrack Posted May 10, 2020 Share Posted May 10, 2020 There is one thing that rules overall, and which can't be trained for - practical, hands-on experience. The long experience of "old hands" who have experienced every possible combination of things going wrong, and who know the way to handle the current Charlie Foxtrot that has occurred, is invaluable. Thus the reason for older people for leaders, Many a country has run very successfully with a leader well past "retirement age". Most of the Boomer generation has a trade or skill developed over a wide range of experiences, and training from many older people with their skills and knowledge handed down. They have a multitude of skills that the younger "me-me-me, shallow entertainment, smartphone and computer generation" lack. Many young people lack good hands-on practical skills. They can be very proficient at manipulating key strokes and finding ways to do things with computer programmes, but they lack the important hand-on skills such as handling equipment, approaches to jobs, construction and practical repair work. I was intrigued to find that all the Railways in W.A. up to 1929 were built by men with no tertiary education. These blokes had no degrees in engineering, but they were masters of railway construction in the most practical manner, using time-honoured skills, approaches and rules. They knew the cross-slope required for certain curve radiuses to prevent trains falling off the rails at speed - or they knew the maximum speed limits for those curve radiuses. Nowadays, a railway engineer relies on a computer programme to generate the figures - but he often has no hands-on practical skills directly related to railway building. A mechanical engineer I was in partnership with told me a story of a Middle Eastern engineering graduate he worked with. The bloke asked him if he might know why his electric razor had stopped working. My partner said to him, "Have you emptied the cut whiskers out of it recently?". The Middle Eastern bloke looked a bit stunned, and said, "No, how do you do that?" So he was shown how to flip the top of the electric razor and empty the cut whisker remnants out - a move that amazed the Middle Eastern bloke. And my partner exclaimed, "And this bloke had an engineering degree!". 2 Link to comment Share on other sites More sharing options...
facthunter Posted May 10, 2020 Share Posted May 10, 2020 When you've worked on a lot of stuff and done a bit of Materials and Structures study you can look at some things and "see" by looking that certain Parts are too lightly built. Likewise that some are over designed. Naturally these should be backed up by calculating loads/stress and where appropriate static or inflight testing. often with strain gauges. The B 727 Tail when test flown was discovered that the flight loads were 250% (Two and a half) of what was expected. That's hell of a lot of underestimation and it's unusually high. Being essentially a new type (rear engines T tail) the assumptions must have been way off. Of course it was beefed up and never gave issues but is a very highly loaded component. Nev 1 Link to comment Share on other sites More sharing options...
turboplanner Posted May 10, 2020 Share Posted May 10, 2020 When you've worked on a lot of stuff and done a bit of Materials and Structures study you can look at some things and "see" by looking that certain Parts are too lightly built. Likewise that some are over designed. Naturally these should be backed up by calculating loads/stress and where appropriate static or inflight testing. often with strain gauges. The B 727 Tail when test flown was discovered that the flight loads were 250% (Two and a half) of what was expected. That's hell of a lot of underestimation and it's unusually high. Being essentially a new type (rear engines T tail) the assumptions must have been way off. Of course it was beefed up and never gave issues but is a very highly loaded component. Nev Interesting; they must have used multiple engineers. There's a film floating around of the wing root test of the B727. They locked down the fuselage to the floor, hooked a chain on to a wingtip, and winched the wingtip upwards, quite slowly because it built up viewing suspence. Up through about 15 degrees, 20 degrees, 30 degrees, 40 degrees, 50 degrees, 60 degrees, 70 degrees and still it was going up noiselessly. By this time the wing tip section was pointing upwards at 90 degrees, and still on it climbed and finally there was a BANG! and the factory filled with dust, pigeons departed and the broken wind swung back and forth. Made me very happy to fly in a B727 when the weather was rough, although the way the luggage racks pulled away from the ceiling then back again hour after hour had me concerned. Link to comment Share on other sites More sharing options...
facthunter Posted May 10, 2020 Share Posted May 10, 2020 They did test the wing through about 27 feet of movement of the tip. (the 707 was much more) They got way beyond required strength but kept going to see what would happen The top surface of the centre section failed in compression ending up in small pieces. They just beefed that up and never tested it subsequently because it was way over design requirements. Nev Link to comment Share on other sites More sharing options...
antonts Posted May 10, 2020 Share Posted May 10, 2020 Which is a good reason to have a practice every few flights. it does not work this way. If it is DR and other independent navigation - it must be done every time, with full precision and procedures, not only practiced when you have time and resources, like a funny toy. Or at the moment when everything collapsed you are in the same nowhere. So it is obvious unreal, it rises the cost (efforts, time spent, risks due to distraction from control, requirements for track planning etc) so high that the whole process becomes impossible. Its like to always carry full month survival kit with you, 50 kg backpack even if you are walking to grocery store. So all these emergency procedures must work without prehistory, ie they are obligatory absolute means dependable - GPS, radio beacons etc. You fear that your panel GPS fails? take 5 more GPSes with you - tablet, mobile phone, wrist watch, radio and fitness bracelet, everything now has built-in GPS. Even if it does not give precise information, real map and course directly to home door it will be enough to be not lost. At least you find the way to somewhere, not obligatory to where you wanted, but to safety. And in the case of global GPS fault (sudden nuclear war with space explosions, killing all satellites in minutes without any preliminary signs) navigation will be not the most significant problem. Link to comment Share on other sites More sharing options...
Flightrite Posted May 12, 2020 Share Posted May 12, 2020 Everything in aviation is based on risk, calculated risk, life without risk is not life at all? All one can do on a personel level is reduce their own risks, that could be by carrying a dozen GPS devices all the way up to not even getting out of bed in the first place?? Link to comment Share on other sites More sharing options...
facthunter Posted May 12, 2020 Share Posted May 12, 2020 Having redundancy based on ONE source system isn't redundancy. In Aviation never rely on only one source of info without an independent verification process existing . Eg Erebus & 3 AH's in an IFR cockpit and numerous fire warning circuits with test systems..etc Nev Link to comment Share on other sites More sharing options...
jackc Posted May 12, 2020 Author Share Posted May 12, 2020 Having redundancy based on ONE source system isn't redundancy. In Aviation never rely on only one source of info without an independent verification process existing . Eg Erebus & 3 AH's in an IFR cockpit and numerous fire warning circuits with test systems..etc Nev The main thing is, however you configure your navigation scheme and it’s backup.....it must be a simple operation. I have just gone through grief with AvPlan, just too complicated but I contacted support today and I am now on a ‘lite’ IOS version to see how I go with it. Whilst I have never used anything in a real world flight environment, I am planning for the day:-) 1 Link to comment Share on other sites More sharing options...
M61A1 Posted May 13, 2020 Share Posted May 13, 2020 If you retire without a plan or interests you usually don't last long. Boredom, then health issues, then the down hill slide till it's all over. The indispensable Man When you are feeling that you are important And your ego is out in full bloom You stand there and take it for granted You're the best qualified in the room When you feel that the thought of your going Will leave an unfillable hole Just follow this simple example And see how it humbles your soul Take a bucket & fill it with water Put your hand in it up to your wrist Pull it out and the hole that's remaining Is the measure of how much you'll be missed. You can splash all you like when you enter And stir up the water galore But stop and you'll see in a minute It looks just the same as before The moral of this quaint example Is do just the best that you can Be proud of yourself but remember There is No Indispensable Man This used to be on the back of the main door at 482 SQN Field Training Flight at Amberley in the eighties. It has stuck with me all those years. 2 Link to comment Share on other sites More sharing options...
M61A1 Posted May 13, 2020 Share Posted May 13, 2020 The thread is" navigation using the VOR" (VHF Omi Range). Clearly it is becoming decommissioned and there's less ground radar which once you could have used in emergencies. GPS is fine but dependent on factors over which a pilot has no control.. IFR flights had to PLAN with certain TSO'd Instruments on which the pilot is currently rated ticked off so it can be approved.. IF it's part of the planes equipment (often duplicated)and you were rated on it and it's sufficient for the route and conditions likely to be encountered you GO. Your plan is approved . IF an aid goes U/S and you don't have another SUITABLE to cover you, you don't comply with the clearance any more. You were often trained on a DME homing procedure also which could get you down to a level where you could expect to be visual if the forecast allows it.. Use of any of these aids relates to weather and fuel for alternates, let down procedures and holding requirements as well as navigation between waypoints on specific IFR routes. ALL that doesn't have much relevance to what WE do which should still rely mostly on map reading whether google maps or paper ones. and track keeping The WAC chart with height indications (Hypsometric tints) and contour lines is basic to that at a planning stage and in flight though not without issues in an open cockpit aircraft. On one of your flights just cover your GPS and see how you go after a while. It's easy to be too dependent on the GPS. Nev s The Ultra EFIS I have has a VOR but is based on GPS and doesn’t use radio signals The good bit about that is that you can load your own points of interest and still navigate to them using VOR as if they had their own station. Link to comment Share on other sites More sharing options...
facthunter Posted May 13, 2020 Share Posted May 13, 2020 A lot of VOR's didn't quite line up depending on where they are sited. You changed over at about mid distance. VHF is line of sight so the higher you fly the better the signal. You wound the radial for the track that you wanted into it. Nev Link to comment Share on other sites More sharing options...
Ironpot Posted May 13, 2020 Share Posted May 13, 2020 can anybody help me with this one please? I know about TTI etc, however on the modern glass cockpits the identifier will show on the VOR frequency eg "CG" Gold Coast, "TL" Townsville etc. My question is - when the identifier appears beside the frequency, does it satisfy the Test requirement and dispense with the necessity of listening to the morse. I ask cos "SU" doesn't appear for Sunshine Coast for some reason. If so, can you point me to the relevant clause in the legislation or the authority? The reason I ask is because I'm sure I have read somewhere in the past that an identifier is all that is is required to use a VOR but I can't find and it may be from the US or Europe and not applicable to Australia. Link to comment Share on other sites More sharing options...
facthunter Posted May 13, 2020 Share Posted May 13, 2020 Don't know about the glass set up but the usual VOR had a failure flag .You always had to ident when transferring or setting a course.. perhaps none of this is relevant to you. nev Link to comment Share on other sites More sharing options...
Flightrite Posted May 13, 2020 Share Posted May 13, 2020 Don't know about the glass set up but the usual VOR had a failure flag .You always had to ident when transferring or setting a course.. perhaps none of this is relevant to you. nev Most modern EFIS have a red 'NAV' flag as well if reception is lost. Link to comment Share on other sites More sharing options...
antonts Posted May 14, 2020 Share Posted May 14, 2020 Having redundancy based on ONE source system isn't redundancy. In Aviation never rely on only one source of info without an independent verification process existing . Eg Erebus & 3 AH's in an IFR cockpit and numerous fire warning circuits with test systems..etc Nev if GPS system (satellites etc) fails - loss of your current position will be the smallest problem in the world. At least any smart mobile/tablet can position you with precision of 2-3 miles just on mobile network, without gps reception at all, this is enough to find the way home. Erebus and other DR losses happened due to independent systems, where you have to rely on youself only. Link to comment Share on other sites More sharing options...
kgwilson Posted May 15, 2020 Share Posted May 15, 2020 If the GPS systems fail due to a CME the mobile phone system and practically all electrical communications world wide will also go down. If your aircraft engine is not dependent on electronics it should continue to function but navigation will be 100% manual and if you do not have any steam instruments it will be seat of the pants flying like you have never experienced before. Link to comment Share on other sites More sharing options...
Thruster88 Posted May 15, 2020 Share Posted May 15, 2020 If the GPS systems fail due to a CME the mobile phone system and practically all electrical communications world wide will also go down. If your aircraft engine is not dependent on electronics it should continue to function but navigation will be 100% manual and if you do not have any steam instruments it will be seat of the pants flying like you have never experienced before. Some of us have that seat of the pants experience ?? 3 Link to comment Share on other sites More sharing options...
turboplanner Posted May 15, 2020 Share Posted May 15, 2020 Some of us have that seat of the pants experience ??[ATTACH alt=20190613_122527_resize_1.jpg]53209[/ATTACH] Could be eye-watering in bindii country! Link to comment Share on other sites More sharing options...
M61A1 Posted May 15, 2020 Share Posted May 15, 2020 Could be eye-watering in bindii country! Or scotch thistle.... Link to comment Share on other sites More sharing options...
KRviator Posted May 16, 2020 Share Posted May 16, 2020 Having redundancy based on ONE source system isn't redundancy. In Aviation never rely on only one source of info without an independent verification process existing . Eg Erebus & 3 AH's in an IFR cockpit and numerous fire warning circuits with test systems..etc NevExcept that CAsA have decreed that having only 1 TSO'd GPS (C145/6) is sufficient for sole-means IFR navigation without requiring an alternate! What would happen at night, in IMC enroute if that single GPS were to fail is the million-dollar question. I don't have a VOR in the RV, and don't see the point either. Any TSO'd GPS newer than C129 is sufficient to push the "Time to positive fix" out from 30 minutes for VFR to 2 hours, you don't need station passage or intersecting radials from a VOR. A waste of time, money and weight in a modern cockpit. The only reason I'd install one would be for an ILS, but never a standalone VOR. Anyway...Here's a bit of my handiwork from a few years ago, showing the remaining VOR's in Australia and their effective ranges. Nationwide coverage at 10,000'. Red is ASA, Blue is private. Green is DoD. Victoria 5,000'. Victoria 10,000'. NSW 5,000'. NSW 10,000'. Queensland 5,000'. Queensland 10,000'. 1 Link to comment Share on other sites More sharing options...
DenisPC9 Posted October 28, 2020 Share Posted October 28, 2020 On 10/05/2020 at 12:13 PM, facthunter said: We even took the thing to Cocos (keeling) islands where each wave looks much like the next one and if we missed it, had no place to range to. Just two hours "Island holding" at running on Vapour rate. Have a look where it is on the Map. Regular Gov't Charter, about once a month. Amazing we didn't lose one.. Nev I was posted to Cocos 1979 - 81 the RAAF used to fly in on P3s, the occasional C130 and the even rarer VIP Sqn. The P3 crews used to tell me as part of a NavEx they used to tune in to VKW (Broadcasting on 1404 kiloHertz to ships in the air, planes at sea and anyone else silly enough to be listening 😉) carrier wave (from memory) more than a few hundred miles out and just follow the strengthening signal until they picked up the voices, then they knew they were less than 100 miles out. 12.05S 96.53E burnt into my brain. 1 Link to comment Share on other sites More sharing options...
Old Koreelah Posted October 28, 2020 Share Posted October 28, 2020 On 13/05/2020 at 3:12 PM, M61A1 said: This used to be on the back of the main door at 482 SQN Field Training Flight at Amberley in the eighties. It has stuck with me all those years. My brother was there too and passed that poem on to me. Link to comment Share on other sites More sharing options...
coljones Posted October 29, 2020 Share Posted October 29, 2020 On 10/05/2020 at 12:52 PM, onetrack said: There is one thing that rules overall, and which can't be trained for - practical, hands-on experience. The long experience of "old hands" who have experienced every possible combination of things going wrong, and who know the way to handle the current Charlie Foxtrot that has occurred, is invaluable. Thus the reason for older people for leaders, Many a country has run very successfully with a leader well past "retirement age". Most of the Boomer generation has a trade or skill developed over a wide range of experiences, and training from many older people with their skills and knowledge handed down. They have a multitude of skills that the younger "me-me-me, shallow entertainment, smartphone and computer generation" lack. Many young people lack good hands-on practical skills. They can be very proficient at manipulating key strokes and finding ways to do things with computer programmes, but they lack the important hand-on skills such as handling equipment, approaches to jobs, construction and practical repair work. I was intrigued to find that all the Railways in W.A. up to 1929 were built by men with no tertiary education. These blokes had no degrees in engineering, but they were masters of railway construction in the most practical manner, using time-honoured skills, approaches and rules. They knew the cross-slope required for certain curve radiuses to prevent trains falling off the rails at speed - or they knew the maximum speed limits for those curve radiuses. Nowadays, a railway engineer relies on a computer programme to generate the figures - but he often has no hands-on practical skills directly related to railway building. A mechanical engineer I was in partnership with told me a story of a Middle Eastern engineering graduate he worked with. The bloke asked him if he might know why his electric razor had stopped working. My partner said to him, "Have you emptied the cut whiskers out of it recently?". The Middle Eastern bloke looked a bit stunned, and said, "No, how do you do that?" So he was shown how to flip the top of the electric razor and empty the cut whisker remnants out - a move that amazed the Middle Eastern bloke. And my partner exclaimed, "And this bloke had an engineering degree!". Speaking as a relatively old fart i can say quite categorically that there are quite a few of us who are as dumb as dogshti and arrogant to boot. Having years of experience might also be doing the same narrow job with the same narrow mind learning nothing year in and year out. Link to comment Share on other sites More sharing options...
facthunter Posted October 29, 2020 Share Posted October 29, 2020 (edited) Some oldies are like that. It is said "It's a Pity that YOUTH is wasted on the young". attributed to GB Shaw, I believe. True when I look back on how I approached things. Always pushing limits Repetition 's only experience is experiencing BOREDOM. Lot's of Employers recognise EXPERIENCE as important particularly in Aviation. Types, where and how. Not just simply hours . Some people get bored easily (ME). Others like a comfortable semi seclusion where the pressure is not high and the weekend is the relief. Age can bring deterioration so it's a balancing act. IF at any age, you feel there's no more to know you will be putting a cap on what you absorb. Retain the questioning mind of the young child where most things are a wonder, rather than a yawn. Be involved rather than wanting to be entertained . Build and construct rather than just purchase to say Look, I have one of these . Aren't I SO successful? Nev Edited October 29, 2020 by facthunter 1 Link to comment Share on other sites More sharing options...
