RossK Posted February 21, 2023 Share Posted February 21, 2023 So, during Nav training, I was taught to plan via waypoints. VFR waypoints and Airfields primarily. Ie if we were doing a 100nm leg and there was a waypoint 10nm off track we would plan via the waypoint. With the advent of modern navigation aids, GPS, EFB etc, is this smart or safe. I've recently had 2 experiences where aircraft were around an airfield, not broadcasting their intentions or doing non standard procedures. Had I tracked around these airfields, I could have completely avoided these other unpredictable aircraft. I understand the safety aspect of navigating by map to ground and ground to map references and still do that on the EFB (not just follow the magenta line), but flying into airspace that contains other traffic may not be the safest option, when I have the option to navigate around it. Thoughts?? 1 Link to comment Share on other sites More sharing options...
old man emu Posted February 21, 2023 Share Posted February 21, 2023 Another example of "I'll do the right thing, but I can't stop others being ignorant, entitled dickheads." On a lengthy leg, usually determined by the time to fly it, I surmise that incorporating readily identifiable features is the way to remain on Track. And it's not usually necessary to overfly a waypoint if your flight plan can indicate a position where you are abeam the waypoint. All you have to do on your WAC is draw a line from the waypoint to your track to intersect at 90 degrees. Admittedly if there isn't a clear line of sight from your track to the waypoint, you might have to dog-leg your track. 2 Link to comment Share on other sites More sharing options...
CT9000 Posted February 21, 2023 Share Posted February 21, 2023 A waypoint does not need to be an airfield. I rarely use airfields as waypoints due to the danger. It is easy to use an easily identifiable feature like a dam or town etc. At an airfield, when you think about it the inbound traffic will be looking down at the sock or for circuit traffic. The over flying traffic will probably be looking at the flight plan or tablet (map) for time / next heading etc. and nobody is really looking for traffic. Safer to not be over the top unless plenty high. 1 Link to comment Share on other sites More sharing options...
kiwiaviator Posted February 21, 2023 Share Posted February 21, 2023 Point 1: Airfields can be great waypoints if you are well above pattern altitude. Point 2: A lot of pilots now fly direct from A to B following the magenta line so waypoints slightly off track can be a good thing to avoid being on the same line. Point 3: Use your recommended cruising altitudes when cloud cover allows. 1 Link to comment Share on other sites More sharing options...
KRviator Posted February 21, 2023 Share Posted February 21, 2023 I guess the big question is "What's your route length?" - the reason for asking is, for anything less than 10mins or so at 8,500 or 9,500, I will climb as high as I can and stay there as long as I can. That being so, overflying airports is not as risky as doing so at lower altitudes and I routinely overfly enroute airports at high altitude. Doing so is beneficial in that you both have good glide options, , better VHF & ADS-B coverage, ATC knows exactly where you're aiming for (instead of a random dam or HV powerline intersection on the VTC - and assuming you actually have a plan in the system...) and barring any traffic inbound to those airports, there's little to no conflicting traffic. So if you're going a fair way, go high and go over airports if they won't take you too far out of your way. If you have to stay low, for cloud or CTA, then planning around airfields is sensible to avoid traffic, so long as you still have a decent forced landing option within glide range. 1 Link to comment Share on other sites More sharing options...
facthunter Posted February 21, 2023 Share Posted February 21, 2023 A waypoint MUST be able to be positively identified not what you "HOPE" it is. Being somewhere where feeder/ Regional airline traffic may be climbing or descending to/from Should be avoided if possible. Be where others are not is safer and vertical separation is the most sure one. Nev 2 Link to comment Share on other sites More sharing options...
mkennard Posted February 21, 2023 Share Posted February 21, 2023 In Avplan I use abeam so you can still see the airfield but not need to go directly over. Radio calls and keeping an eye or 2 out is still a good idea. 2 1 Link to comment Share on other sites More sharing options...
walrus Posted February 21, 2023 Share Posted February 21, 2023 Ah Yes, GPS assisted collisions.If you are stupid enough to use published waypoints exactly as they are printed then you have lost one potential element of protection against a mid air collision. In other words two rather big holes in the cheese have just aligned. Your track if you do this will mirror someone else doing the same thing. That means either an overtaking or head on encounter. You can pray for GPS errors to save you but consider, if both of you have the same band receiver (eg. GNS 430) then as you close with the other aircraft the position errors due to instrument accuracy, or error, are potentially going to be identical. This means that all you have to save you is differing altitudes when you cross. Good luck with that. I have personally met another aircraft exactly head on - except we were about 500 ft of altitude apart. Please use offsets, and not obvious ones either. 2 Link to comment Share on other sites More sharing options...
skippydiesel Posted February 21, 2023 Share Posted February 21, 2023 (edited) All comes down to personal preference/comfort zone. I fly the shortest rout at the most efficient VFR cruising altitude, subject to bladder needs, weather & terrain. I like to be a minimum of 1000ft above terrain at all times -This may result in a "leg" cruising altitude that is well over 1000ft above the ground, I am actually passing over. It also means that "scud running" is never an attractive proposition. I don't have an autopilot ,so my intention to fly to the right of the magenta line is compromised by random inattention, which may impact on the potential for a head on🤩 In addition to inbound to landing calls, I make a point of making an "All Stations" call to advise a change in course altitude/direction and if passing within 10Nm of an airfield giving a similar call to advise aircraft, in the vicinity, of my existence location & intentions. Edited February 21, 2023 by skippydiesel 1 Link to comment Share on other sites More sharing options...
facthunter Posted February 21, 2023 Share Posted February 21, 2023 There is no doubt the newer Nav aids promote the risk of being precisely head on, on more occasions. Nev 1 Link to comment Share on other sites More sharing options...
Neil_S Posted February 22, 2023 Share Posted February 22, 2023 (edited) 19 hours ago, facthunter said: There is no doubt the newer Nav aids promote the risk of being precisely head on, on more occasions. Nev And the hemispherical rules promote the risk of being on a non head on collision course if above 3000ft AMSL........ Edited February 22, 2023 by Neil_S Link to comment Share on other sites More sharing options...
skippydiesel Posted February 22, 2023 Share Posted February 22, 2023 My understanding - Previously: If flying at/below 5000ft you could be at any altitude you chose . Now : If flying at or below 3000ft you can be at any altitude you choose. Further - I think the rules is something along the lines of .......subject to clear of terrain. What does this mean for safety when in the training area? My training area has terrain to just under 2000ft, so at 3000ft, I only have 1000ft of safety, when conducting stalls & the like. I don't like this very much, so I still go up to above 4500-5000 ft - am I breaking the rules??? 1 Link to comment Share on other sites More sharing options...
mkennard Posted February 22, 2023 Share Posted February 22, 2023 Also, there can be cloud which makes it difficult. Link to comment Share on other sites More sharing options...
skippydiesel Posted February 22, 2023 Share Posted February 22, 2023 7 minutes ago, mkennard said: Also, there can be cloud which makes it difficult. Yeah! what then?? I have always observed the VFR hemispherical cruising altitudes when on a trip even when under the 5000ft (now 3000ft) threshold - but when training??????? Link to comment Share on other sites More sharing options...
RossK Posted February 22, 2023 Author Share Posted February 22, 2023 (edited) 41 minutes ago, Neil_S said: And the hemispherical rules promote the risk of being on a non head on collision course if above 3000ft AMSL........ One of the situations was, We were tracking just east of north, 007 at 5500ft, other aircraft was tracking just east of south, probably 170 at 5500. The didn't make any inbound calls, overhead calls etc or reply to my call. They were transmitting ADSB out though so I did see them from about 15nm separatation. When they were 8nm (2 minutes) separation I called them, no reply so I pushed the nose down and we dropped to 5000ft. We only had visual on them for about 5 seconds before they flew over the top of us. It was close enough to see that it was a strutless, retractable Cessna, and yes, not a media Cessna, a real one. Edited February 22, 2023 by RossK 2 1 Link to comment Share on other sites More sharing options...
Jabiru7252 Posted February 22, 2023 Share Posted February 22, 2023 20 hours ago, facthunter said: There is no doubt the newer Nav aids promote the risk of being precisely head on, on more occasions. Nev One should always fly right of track so if two planes are flying the same track, in opposite directions and are at the same altitude, they should pass each other. 3 Link to comment Share on other sites More sharing options...
facthunter Posted February 22, 2023 Share Posted February 22, 2023 Things like that can work. There's not always a defined track in an area but whatever you do must help if it's sensible... It's legitimate to fly a road a railway line or a powerline. A road in a remote area is helpful if you have to forced land near it or on it.. Nev 1 Link to comment Share on other sites More sharing options...
Student Pilot Posted February 22, 2023 Share Posted February 22, 2023 Always flown straight A to B except over water, I tend to skirt around large areas of water. 1 Link to comment Share on other sites More sharing options...
facthunter Posted February 22, 2023 Share Posted February 22, 2023 Difficult when you are going Perth-Cocos. Nev 2 Link to comment Share on other sites More sharing options...
old man emu Posted February 23, 2023 Share Posted February 23, 2023 On 22/02/2023 at 1:36 PM, skippydiesel said: VFR hemispherical cruising altitudes On 22/02/2023 at 1:38 PM, RossK said: tracking just east of north, 007 at 5500ft, other aircraft was tracking just east of south, probably 170 at 5500. You have confused me. I'm looking at the VFR levels diagram. If an aircraft is flying on a magnetic track of 007 its track would be a bit like this: An aircraft flying on a track of 170, its track would look like this But by making these diagrams I see your point that these tracks could conflict depending on the relative starting and end points of the respective journeys. Link to comment Share on other sites More sharing options...
pmccarthy Posted February 23, 2023 Share Posted February 23, 2023 Had that today. We were tracking about 090 and someone was tracking 010 across us at same altitude. They crossed our path about 10 mile ahead. Thanks Ozrunaways. 1 1 Link to comment Share on other sites More sharing options...
skippydiesel Posted February 23, 2023 Share Posted February 23, 2023 1 hour ago, pmccarthy said: Had that today. We were tracking about 090 and someone was tracking 010 across us at same altitude. They crossed our path about 10 mile ahead. Thanks Ozrunaways. Do you have a transponder??? Link to comment Share on other sites More sharing options...
pmccarthy Posted February 23, 2023 Share Posted February 23, 2023 9 hours ago, skippydiesel said: Do you have a transponder??? Had a Skyecho and a Mode C. Link to comment Share on other sites More sharing options...
old man emu Posted February 23, 2023 Share Posted February 23, 2023 Years ago, wasn't the system quadrantal? I know that this applies to IFR, but if it's good enough for those conditions, why not for VFR. It's not as though it would incur great disruption to what we have now, and it has the advantage of having pilots using the same system from their very first TIF. Actually, every one of us now has the opportunity to have a say on this to Government and subsequently to CASA. The Government is calling for submissions into the future of aviation in Australia to 2050. There is a wide range of topics, but safety is one of them. If enough people wrote a short submission just on this topic, it would gain attention. You can read about the White Paper here: https://www.infrastructure.gov.au/infrastructure-transport-vehicles/aviation/aviation-white-paper and see the terms of reference here: https://www.infrastructure.gov.au/infrastructure-transport-vehicles/aviation/aviation-white-paper/terms-of-reference Link to comment Share on other sites More sharing options...
RossK Posted February 23, 2023 Author Share Posted February 23, 2023 4 minutes ago, old man emu said: Years ago, wasn't the system quadrantal? I know that this applies to IFR, but if it's good enough for those conditions, why not for VFR. It's not as though it would incur great disruption to what we have now, and it has the advantage of having pilots using the same system from their very first TIF. I'm not sure that's current OME. My understanding is; VFR Fly Half thousands, ie Even thousands plus 500 westward, odd thousands plus 500 eastward. IFR fly Thousands ie, Even thousands westward, odd thousands eastward. Keeps IFR and VFR separate at all times. But I don't fly IFR, so could be wrong. Thanks for all the replies. Particularly mkennard, I was unaware of the "pass abeam" function and will be using that from now on. The other thing this has taught me is that whilst I saw them 15nm away on the tablet, that's only 4min when the closing speed is 230 knots. I left it until 8nm, 2mins, away before I started to take action - made my radio call, waited for a response, none. Probably only left myself 1 minute to avoid. I need to be more proactive, earlier, to be safer. 4 Link to comment Share on other sites More sharing options...
