Guest Andys@coffs Posted August 2, 2014 Posted August 2, 2014 FT I can solve this problem by moving the fuel tanks out of the relatively thin chord wings and back into the fuselage, however in doing so I probably introduce W&B issues where there are none/minimal fuel related today and probably have to settle for a lower total fuel load...I'll stick with what I have and knowing the compromises I must therefore make, live with them. Knowing is the answer and understanding that aircraft are a combination of a whole sets of compromises. What is an Ok compromise for me may not be an Ok one for you and that's fine, cause otherwise we would all be flying the same thing.
fly_tornado Posted August 2, 2014 Posted August 2, 2014 my mum's is ok, got the diesel though. maybe your borther should have got the diesel?
rankamateur Posted August 2, 2014 Posted August 2, 2014 Quote The speedo doesn't work in my Jackaroo. Tip - You need the cable connected to make the speedo work, I have had a few over the years like this, but they have less k's on them when you go to sell them. Makes it easier to get fined for speeding though. 1
planesmaker Posted August 2, 2014 Posted August 2, 2014 "As always we see comment about how good the 912 is, however just 20 hp short of powering many Jabirus. My point being, the arguabley most popoular and universally aclaimed fuse in australian RAA aircraft, j230, canot be powered by the engine rotax supporters promote." I disagree jet jr. A 912s will perform equally or better than a jab 3300 in a 230 airframe if fitted with a CS prop. I regularly take off using only 100hp at a higher gross wt than RAAus allows with more than acceptable performance. ie 650kg with 800 plus ft/min. There are many airframes of similar wt to the j230 that perform well with the 912s. Tom 2
Teckair Posted August 2, 2014 Posted August 2, 2014 Quote Tip - You need the cable connected to make the speedo work, I have had a few over the years like this, but they have less k's on them when you go to sell them. Makes it easier to get fined for speeding though. Yep no cable wires instead, gearbox part is working, got to get around to pulling the dial out of the dash next.
Oscar Posted August 2, 2014 Posted August 2, 2014 Quote Who needs brumby parts? Anyway, we cant all use parts from supercheap. Merv: help will soon be at hand for your parts-supply envy problem! Bunnings have a buy policy that basically says to China: 'send 20 containers of anything'. I reckon you can confidently expect that there will be Brumby parts shelf on Aisle 24, stuck between the Pool Cleaner equipment and the 16-burner Barbeques, (and with the caveat of the fact that the ACTUAL part you need is not there - it never bloody is at Bunnings) - you'll be jake! And Selleys will have 'Brumby in a tube' parts anyway, very soon. 2 1
Oscar Posted August 2, 2014 Posted August 2, 2014 Quote I will rest easy knowing at least, finally, someone, somewhere is trying to fix the problem. Merv - commiseration. It would appear, from the comments of Andy and Don, that the CEO is 'off the hook' in regard to an official RAA jihad against Jabiru. Now, I would hope that an official comment from said CEO that the comment reported was false will be forthcoming, but even without that it looks as if your peaceful nights are off the agenda - again. I'd like to say that I share your pain - but we both know that that would be a continuance of bullsh1T, wouldn't we? Still, chin up, me old China, maybe one day it will happen. If the Heavens are warming up - as we are informed - than Hell will be experiencing a significant drop in its ambient. Possibly even enough to induce Carby ice?
SDQDI Posted August 2, 2014 Posted August 2, 2014 Quote What is more of an issue here which hasn't been mentioned is the perception of unsafe practices that people will have of the RAA operation at Archerfield. Yes this has been the second crash with this aircraft but they have also had another making three incidents. The pilot used his training, skill and a huge amount of good luck to manoeuvre the aircraft to a successful landing (any landing you can walk away from is supposed to be OK, right?) but really, is their operating regime flawed? For instance, using mogas in an aircraft where weather conditions could increase the risk of carby icing or was it a case of having too much air in the tanks? Comments locally at Archerfield seem to support the later, so was proper flight planning carried out to ensure enough fuel carried for flight and reserves? Ok so Don has said 100% definitely not out of fuel but my question (sorry for dredging a post so far back) How much difference does Mogas make to Carby icing?
SDQDI Posted August 2, 2014 Posted August 2, 2014 Quote To be blunt there is only 1 filling volume that I personally believe you can take to the bank and that's full..Andy Sorry to be argumentive Andy but I believe there are two volumes you can take to the bank one is full the other is empty. Trouble is taking empty to the bank could find you cashing it in.......... (That sounded better in my head. I know after dons post fuel levels are irrelevant in this thread just couldn't hold it in.)
AVOCET Posted August 2, 2014 Posted August 2, 2014 Quote Ok so Don has said 100% definitely not out of fuel but my question (sorry for dredging a post so far back)How much difference does Mogas make to Carby icing? I don't think it does ? But I'm no x/spert
motzartmerv Posted August 2, 2014 Posted August 2, 2014 Quote Merv: help will soon be at hand for your parts-supply envy problem! Bunnings have a buy policy that basically says to China: 'send 20 containers of anything'. I reckon you can confidently expect that there will be Brumby parts shelf on Aisle 24, stuck between the Pool Cleaner equipment and the 16-burner Barbeques, (and with the caveat of the fact that the ACTUAL part you need is not there - it never bloody is at Bunnings) - you'll be jake! And Selleys will have 'Brumby in a tube' parts anyway, very soon. Oscar... What the hell are you on old sport? Can I get some please? What a rant about nothing.. Really? Bunnings? The RAA are 'taking steps' buddy, I recall warning you of this several months ago, and was met with similar self serving, rambling librarian, jabiru share selling rubbish from you then. Read between the lines and suck it up sweet heart. How long did you and your buddies think this would go on for? Youu can fool the punters, but not people that acuatlly know what they are talking about and operate these ...Cough...Engines, daily.. Im glad the CEO or as he stated ( the RAA) has written to CASA. Change is in the air my learned friend, change that will only improve safety, which is what we all want isnt it? 3
dunlopdangler Posted August 2, 2014 Posted August 2, 2014 Quote Ok so Don has said 100% definitely not out of fuel but my question (sorry for dredging a post so far back)How much difference does Mogas make to Carby icing? Pretty simple really when you think about it, If your buying mogas, there is the possibility of contamination at the bowser with ethanol which infuses with water very well and with icing conditions prevalent on the day could have been as simple as that to stop the donk if it wasn't empty tanks as was quoted to me from people at Archerfield and I'm not saying they are 100% right neither, Engine ran fine after it was recovered so what needs to be determined is why the pistons weren't getting the fuel/air mixture to support combustion.. 1
SDQDI Posted August 2, 2014 Posted August 2, 2014 Oscar sounds educated That cannot be debated He likes to tickle the nerve Of the famous forumite Merv He does like his Jabs He says CAMits are fab Our knowledge compared to his, pales His vocabulary never fails Makes me wonder what he is sellin Is his last name really Llewellyn? Oscar your probably a nice bloke This post is meant to be a joke 1 5
AVOCET Posted August 2, 2014 Posted August 2, 2014 Quote Oscar sounds educatedThat cannot be debated He likes to tickle the nerve Of the famous forumite Merv He does like his Jabs He says CAMits are fab Our knowledge compared to his, pales His vocabulary never fails Makes me wonder what he is sellin Is his last name really Llewellan? Oscar your probably a nice bloke This post is meant to be a joke I've my suspicions also , there's more that one on this forum ?
dan3111 Posted August 2, 2014 Posted August 2, 2014 If they had more time the locals would have put it on on blocks and stole the wheels too there already got the fuel . 1
DrZoos Posted August 2, 2014 Posted August 2, 2014 I just want a Rotax powered Jab and we could all be happy 2
rankamateur Posted August 2, 2014 Posted August 2, 2014 Zoos you can't get a Camit powered Jab so you have no hope of getting a factory Rotax. 1 1
Old Koreelah Posted August 2, 2014 Posted August 2, 2014 Quote Can you still buy a car that doesn't have a working fuel gauge? Good question FT. The Europeans are pretty strict about the reliability of car fuel gauges. Basically a fuel flow meter, the one in our French car is dead accurate, and the one in my plane is pretty good too.
DonRamsay Posted August 2, 2014 Posted August 2, 2014 Quote . . . you have no hope of getting a factory Rotax. If it is a type certified aircraft (not LSA) you could buy a Jab from the factory and register it 24 and then get the CAR 21M authority to swap out the Jab engine for a Rotax. Pretty pricey exercise . . .
